knock sensor harness help
Old Jan 15, 2006 | 02:58 PM
BadKarma99-4spd's Avatar
How in the hell do I separate the plastic harness from the knock sensor?
I think that I am the only person who has trouble figuring out the 18 different harnesses that nissan uses.
Old Jan 15, 2006 | 03:13 PM
njmodi's Avatar
Do I get a tax break?
Is the knock sensor still on the car?
What are you trying to do - that might give us some insight.
If you look at the knock sensor in the V of the engine, you'll see the harness leads out of the V and connects to one of the main engine harnesses. The short harness (known as the knock sensor harness) is only about 18" long (IIRC).
Old Jan 15, 2006 | 03:18 PM
I have the sensor out of the engine. I can not get the actual knock sensor separated from the plastic clip & wire that runs to where-ever.
What do I have to squeeze/push/hammer on the plastic clip that connects the wire to the knock sensor.
Old Jan 15, 2006 | 03:26 PM
njmodi's Avatar
I got ya... now I rememeber
There is a metal clip IIRC that you have to pry out, and then the sensor will seperate from the end of the harness.
FYI - the harness the sensor connects to, is itself a short piece, and can be unplugged from the main engine harness - there should just be a regular connector at that end (with the sort of clip you press to release).
Old Jan 15, 2006 | 03:32 PM
Excellent, I'm going to go try it now.
Old Jan 15, 2006 | 04:11 PM
Thank you it worked fine.
Spent 10 min. getting it out and 10 min. getting it back in. Problem is it took me 2 hours to get the clip undone.
I seriously would never have figured that out.
Thanks again.
Old Jan 15, 2006 | 04:30 PM
njmodi's Avatar
Thanks again.
You're welcome. I almost broke mine trying to force it off (until I saw the cliip)
njmodi's Avatar
Oh btw, be sure to undo, wirebrush/sand/clean the grounds on the plenum. That's where the KS grounds.
Old Jan 15, 2006 | 08:56 PM
PLUMMAXSE's Avatar
Hell, I broke my harness pulling it apart from the KS. The harness wire was so brittle that it needed replacing anyway!! $18 bucks
ballerchris510
Sep 23, 2015 08:46 PM
homeofbacon
Sep 23, 2015 07:17 PM
ac max 92
Sep 17, 2015 07:35 AM
