how to remove tranny from bottom
Old Jan 16, 2006 | 05:07 PM
matts95max's Avatar
so I need to swap trannies and have a pretty good Idea of how im gonna do it but for all you who have done it I would like to know how you did it. I was gonna remove bottom subframe connector from the 2 motor mounts then stick a jack under the motor then unbolt tranny mount from engine bay and then unbolt tranny from the motor?
Old Jan 16, 2006 | 05:20 PM
f550maranello2's Avatar
dont remove the subframe connector... just remove the entire intake, cv shafts, all the transmission electical, the coolant lines.... starter.... and get urself a transmission jack... dont forget to disconnect the torque converter too... should take you now longer than a hour to take it out...
Old Jan 16, 2006 | 05:26 PM
njmodi's Avatar
Do I get a tax break?
You're telling me you can get the auto tranny out of your car (let's assume it's jacked up and on stands) in an hour!
Old Jan 16, 2006 | 05:38 PM
PTownMax's Avatar
I still miss the max
Um you don't have to touch any coolant lines to drop the tranny...:
removing wheels
removing intake
removing starter
removing slave cyl.
disconnecting necessary plugs/sensors
unbolting front struts
DRAIN TRANNY
removing axles
disconnecting shift rods
removing crossmember (I did the front two) - have a jack under the oil pan of the motor...you'll need a tranny jack too - if not, better get someone strong to benchpress that ****
unbolting tranny
dropping tranny
Old Jan 16, 2006 | 05:39 PM
PTownMax's Avatar
Here's a pic of what I just listed
Old Jan 16, 2006 | 05:45 PM
njmodi's Avatar
Actually - he meant the fluid lines that run to the cooler built into the radiator.
Old Jan 16, 2006 | 05:48 PM
PTownMax's Avatar
Uhh....... still......no need to touch em on a 5spd
Old Jan 16, 2006 | 05:50 PM
njmodi's Avatar
Thanks for straightening me out.
Old Jan 16, 2006 | 06:18 PM
matts95max's Avatar
cross member - front 2? why remove slave cylinder?
Old Jan 17, 2006 | 05:47 PM
|Bijan|'s Avatar
UCF Lexus
Front 2 bolts, not the rear 2
You have to take the slave cylinder off the block
Old Jan 17, 2006 | 09:01 PM
KRRZ350's Avatar
Don't be skeered, it's not really that heavy, 108 lb's I beleive. At first, I was wiggling it while my freind worked the jack that was underneath it, then I sayed 'screw this, get that jack out of there' and I just popped it out and muscled it down onto my chest. I removed the lower cross beam/motor mounts, the fsm and haynes says to remove them, and you have to let the motor down to get it out I think, at least it probably makes it easier. You have a motor lift so screw the jack/block under the oil pan, just hold the motor from the top with the lift.
Old Jan 17, 2006 | 09:03 PM
KRRZ350's Avatar
Oh, and you can always check out the 5-speed fsm, it's stickied in the i30 forum!!
fx4five
Oct 18, 2015 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
uttadms31
Sep 30, 2015 05:24 AM
jaydot901
Sep 29, 2015 01:18 PM
