5sp whining noise in reverse
Old Jan 17, 2006 | 01:04 PM
Addicted2Bass's Avatar
My 5 speed makes a whining noise going in reverse and sometimes 1st gear...is that supposed to happen?
Old Jan 17, 2006 | 01:57 PM
CalsonicSE's Avatar
Reverse whining noise is normal...1st gear whining noise is not.
Old Jan 17, 2006 | 02:01 PM
MaxKlinger's Avatar
Reverse gears usually have straight teeth instead of spiral teeth, and are usually noisy. First gear should not be nearly as noisy as reverse.
Old Jan 17, 2006 | 02:10 PM
96blackmaxSE's Avatar
boost me.....
Old Jan 17, 2006 | 03:14 PM
Originally Posted by 96blackmaxSE
first is not as noisy as reverse but its noisier then 2nd, 3rd and so on
Old Jan 17, 2006 | 06:54 PM
Thahman's Avatar
Yeah why does 1st gear sound different than 2nd, 3rd, 4th, 5th?
A whining versus a smooth vroom...
Old Jan 18, 2006 | 04:30 AM
MaxKlinger's Avatar
Has it been doing that since it was new, or do you think this might be a sign of a failing bearing?
Old Jan 18, 2006 | 10:02 AM
mine has been doing it since i got my car a year ago, not sure if this is a sign of bearing failure or not...how can i check to be sure?
Old Jan 18, 2006 | 12:01 PM
MorpheusZero's Avatar
Um, first has always made a whining noise. It's not as pronounced as reverse but definitely there and noticeable when your engine is making little noise. This is normal among 5 speeds AFAIK.
Old Jan 18, 2006 | 12:48 PM
arrrghhh's Avatar
i think first and reverse make that whining noise just because they're such low gears... that and i heard reverse wasn't synchronized like the other gears are (like the spiral teeth as opposed to straight ones)
Old Jan 18, 2006 | 02:14 PM
scrhale's Avatar
*Sniff sniff* I am sooo jealous. I love that reverse whine sound.
"I heard reverse wasn't synchronized like the other gears are"
I wonder if that is why in most cars if you start the car and never release the clutch and then procede to neutral then you grind.
Old Jan 18, 2006 | 02:15 PM
DR-Max's Avatar
Mine's been doing that since day one. The first gear whine is not as bad as the reverse but its there. My tranny is still healthy, no bearing-related noises. Just replaced the clutch about 15k miles ago. No problem whatsoever.
Old Jan 18, 2006 | 02:41 PM
Mishmosh's Avatar
I don't know... mine started whining/groaning and miles later--shot diff carrier bearings.
Old Jan 18, 2006 | 03:20 PM
CalsonicSE's Avatar
Ever since I replaced my tranny (bearing failure), it doesn't whine in 1st gear anymore. In fact, 1st gear now sounds exactly like 2nd gear (no whine). On the other hand, maybe there is a slight whine and I just can't hear it over the y-pipe/GReddy combo.
Old Jan 18, 2006 | 04:01 PM
Thahman's Avatar
Hmm
Before and after the rebuild, 1st gear makes that noise.. but it's not a loud obnoxious abnormal noise, it's just distinct that the rest of the gears...
Old Jan 18, 2006 | 08:19 PM
arrrghhh's Avatar
Maybe the level of whining is different here. I mean it's not a bad whine, and reverse is definitely worse than first, but that's because reverse is a much lower gear than first. If the whine is really, REALLY loud, like if you can compare it to another comparable 5spd (maybe even a max?) and see if it makes AS loud of a whine.
Old Jan 19, 2006 | 10:20 AM
its not that bad i guess it just doesnt sound like the rest of the gears
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
