KYB AGX vs Konis....'kind of long'
Old Jun 7, 2001 | 01:38 PM
maxi-milliyon's Avatar
I slammed my boys 91 honda accord with the AGX's yesterday. After finishing I realized the rear AGX's are off the hook.
The 8 way ajustment really works. I set his on 4 and the rear was so tight. I then went to my Max and pushed down and it was soft compared to his. To sum up everything, when these come out for the Max in August, the konis in the rear may be removed. The front I couldn't notice the change in adjustment.
I tryed a million times to adjust my rear Konis but I get the same response. What the heck are you to do, compress the strut then turn to stiffen. Which way? Please Holla back if you have adjusted the rear Konis. Someone told me how to do it before but when I put it back together it gave the same ride. Do they click when you compress them down and turn or what. My rear is too soft and I know they aren't blown. If worst comes to worst the rear comes off in August. Someone Holla if you had the same problem, or solution."8 way is Hot".
Maxi-milliyon
Old Jun 7, 2001 | 01:49 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Maxi-milliyon
Forum search results for "rear koni adjust", which include a post made by yourself about a month ago. There are a couple of other posts that deal with the subject:
http://forums.maxima.org/search.php?...der=descending
Good luck!
Old Jun 7, 2001 | 01:59 PM
seven's Avatar
when i had my koni rears adjusted to 3 half-turns
they were so stiff that the ride was unbearable. i currently have them set at the softest setting which i feel is a good setting. it's a firm ride with just enough dampening.
i don't know if i would trade Koni's for the AGX's
Old Jun 7, 2001 | 02:22 PM
Maximus98's Avatar
I don't know if I can stand my car looking like a 4X4 right now. I wish the AGX's woulda come out alot sooner. Should I just go with the Koni's?
magiconthetire
Oct 26, 2015 09:03 PM
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
