Front Engine Cover Leaking Oil
Old Jan 18, 2006 | 06:28 PM
97MaximaSE97's Avatar
I had my minor service done today at the Nissan dealership. They found that my front engine cover is leaking oil. They said that it would be 1800 do do the job which involves getting new o rings valve seals and all that. During all the guys technical talk I was thinking (I can get a used low milage engine for like 600 bucks). My question is, is it worth it to perform that service or get a used engine? Will a will the Vq30de-k engine work with no problems on a 98?
Old Jan 18, 2006 | 06:30 PM
njmodi's Avatar
Do I get a tax break?
Do you mean the timing chain cover? Not sure what you mean by the front engine cover..
The DEK will work fine.
Old Jan 18, 2006 | 06:32 PM
Mxrider52's Avatar
I support for what?
Haha what a rip off. There no way it cost anywhere near that. It probably like 100-200 parts. Do it yourself. Go get another quote from a local mechanic
Old Jan 18, 2006 | 06:48 PM
DcMaN's Avatar
do you mean the timing cover ? Cuz the front of our car is really the side. And they will have to pull the motor i believe .
Old Jan 18, 2006 | 06:59 PM
They called it the front engine cover I guess it may be the timing cover. Then they went on to say something about the aluminum cover and a whole bunch of weird mumbo jumbo they said its a huge job but I dunno I'll take the car around and see if they say the same thing. Are the DEK's all cali spec or are there any fedral specs out there?
Old Jan 18, 2006 | 07:01 PM
njmodi's Avatar
Sounds like the timing chain cover is leaking based on ^^^^.... the aluminum, etc. make it clear that it's the timing chain cover.
Old Jan 18, 2006 | 07:03 PM
Ridge Runner's Avatar
Like the others, I'm not sure what you mean. If they mentioned valve seals, sounds like oil leaking into the cylinders. Do you see smoke in the exhaust, especially after idling? Does your car use oil (have to add weekly)? If not, does your engine drip oil on the driveway? Depending on what it is, you may want to wait to get it fixed. $1800 sounds okay for a complete head overhaul, but way to high for a timing chain cover.
Old Jan 19, 2006 | 05:56 PM
They told me its the whole head. Most of the parts inside need to be replace like the o rings and something to do with the pistons and all that. Yeah so do you guys think its worth it to have them fix up the engine or just get another one and install it. I may go to another Nissan service center since non of them are linked together and see if they find the same thing.
Old Jan 27, 2006 | 05:54 AM
If the timing cover is leaking oil, I know the FSM instructions for replacing the timing chain involve stripping a lot off the engine, like the valve covers, P/S pump, AC, etc. This is labor intensive and I have heard estimates of $800 to $1200 to do it.
Does anyone know if you can pull the front timing cover without removing the valve covers, just to replace the RTV sealant? If I've eliminated the rear valve cover gasket as the source of the leak, is the timing chain cover the next logical place to look?
The oil drips from the oil pressure sending unit, but I can see it dripping from the rear exhaust manifold near the front of the engine after the car has been parked.
Old Jan 27, 2006 | 06:20 AM
cardana24's Avatar
Blown
this is the same leak I had and it was infact the timing chain cover. If you pull the passenger side axle out of the tranny (catch the fluid or drain tranny before you do this), you should be able to see it. I paid a shop to fix the leak, and they had to pull the motor.
Old Jan 27, 2006 | 09:05 AM
Tim96I30t's Avatar
If it was me, and my motor had alot of miles, get a new engine(used of course). Why pay a $1000 to fix an old motor, when you can take that money and get new one installed somewhere else. Might cost a little more but very close, depending on how much you pay for the engine and install.
Old Jan 27, 2006 | 09:18 AM
I think my next step is to snug down any nut or bolt I can get a socket on and see if that helps. When I replaced the valve cover gasket there were two bolts on the back that were only finger tight.
If that doesn't do it, I will probably pull the timing chain cover myself and fix it. It will take time but I know this engine's history, and I would hate to discard it for a small oil leak.
Old Jan 27, 2006 | 01:57 PM
Blackwind's Avatar
take a pic. its probaly the VALVE cover. its a common problem on maximas. but most people ignore it.
FlaMark
Aug 21, 2015 11:06 AM
Balkins
Aug 12, 2015 06:39 AM
BassAddictJ
Aug 4, 2015 11:38 AM
