Real Quick; Why wouldnt coils get power/signal?
Old Jan 19, 2006 | 12:09 PM
|Bijan|'s Avatar
UCF Lexus
Im about to go get my car out of the shop, it wont start - no spark.
How do I confirm WHICH wire (out of the 3) is bad?
If I put 6 new coils in will anything change?
What all COULD cause no spark?
I dont have time to search right now, Im pretty busy with work...
PLZ any ideas would help.
Old Jan 19, 2006 | 12:16 PM
Dubbya's Avatar
VK56 Inside
starter?
1 bad coil, even 2 shouldnt cause your car to not start
Old Jan 19, 2006 | 12:21 PM
|Bijan|'s Avatar
UCF Lexus
starter is fairly new
Old Jan 19, 2006 | 12:23 PM
|Bijan|'s Avatar
UCF Lexus
clip one ignition wire at the ECU level and test the voltage there?/
Old Jan 19, 2006 | 12:24 PM
Dubbya's Avatar
VK56 Inside
is the battery putting out the proper voltage? If its been sitting for a while, which it sounds like it has, the battery may just need to be charged. Try a jump start.
Old Jan 19, 2006 | 12:34 PM
njmodi's Avatar
Do I get a tax break?
Sounds like a pad CPS (REF or POS) or bad CmPS issue... you won't get spark (I believe) if one of those are bad...
Old Jan 19, 2006 | 12:37 PM
|Bijan|'s Avatar
UCF Lexus
well yea, I gota get a new battery but I highly doubt thats what's causing it NOT to spark
Old Jan 19, 2006 | 12:39 PM
njmodi's Avatar
And check the fuses (all of them)...
Old Jan 19, 2006 | 12:40 PM
|Bijan|'s Avatar
UCF Lexus
both crank pos. sensors are new
You saying cam. pos. sensor also?
Old Jan 19, 2006 | 12:41 PM
|Bijan|'s Avatar
UCF Lexus
already did that
njmodi's Avatar
Yup. Have them pull codes...
Old Jan 19, 2006 | 12:44 PM
|Bijan|'s Avatar
UCF Lexus
No codes......
Old Jan 19, 2006 | 12:45 PM
|Bijan|'s Avatar
UCF Lexus
Do I need to snip the wire at the ecu level and test it there
to make sure there is no short in the wire from the ecu to the coilpack??
How the f'ckin!
Old Jan 22, 2006 | 06:57 PM
kingrukus's Avatar
no more maxima...
did you get the ballast out yet?
JakeOfAllTrades
Oct 5, 2015 10:40 AM
fx4five
Oct 1, 2015 04:58 AM
zmcneely13
Sep 26, 2015 02:26 PM
