Transmission Swap
Old Jan 21, 2006 | 02:46 PM
iceman82's Avatar
Transmission Swap
My auto tranny is going to get replaced when I get my tax return, had it looked at Im missing 2nd and 4th gear. But I can get a used one for about $950, but I was talking to my wife and she said "if you wanna put a manual in it you can, you just have to teach me to drive it", so I got to thinking how much would it take to swap. I know some of you have done this so i was wondering how much $$$ does it take and what options I have (as far as trannys go, a 5 speed would be awsome but what about a 6 speed)
Old Jan 21, 2006 | 02:50 PM
Mxrider52's Avatar
I support for what?
6 speed no swapping to 5 spd probably gonna run 1500 depending on the amount you get a tranny and parts for
Old Jan 21, 2006 | 09:24 PM
aznsap's Avatar
you can find all the parts you need for about 1000 if you just get all used oem parts for the conversion. it can add up though if you want an aftermarket clutch, sts, stuff like that.
Old Jan 22, 2006 | 01:49 AM
Eyemfaster's Avatar
would you be swapping it yourself? i would imagine the costs for labor would own you.
Old Jan 22, 2006 | 08:31 AM
highoctane79's Avatar
my auto tranny just went out i bought a used one for 250. look on car-parts dot com for a salvage yard close to you and look for a 5spd. that was my regret in the middle of changing them, shoulda bought a 5spd
Old Jan 22, 2006 | 08:45 AM
d00df00d's Avatar
Old enuf to pick his own gears
Another potential 5-speed swapper! Do it right and you DEFINITELY won't regret it (can ya tell I like mine? ).
First things first:
1. Do it right from the get-go. Some 5-speeds had bearings that went bad after 100k-130k miles, so you'll want to avoid that. It'll cost you extra but it'll be worth it.
Your first option is a rebuilt transmission, which you should be able to get for around $1k if it's fresh; less if it's slightly used. Your second option is the transmission out of a '96-'99 Infiniti I30, which will be higher mileage for the price but has a limited-slip differential and didn't have the bearing problems nearly as much. Either way, you'll need to get the corresponding axles: Maxima axles for a Maxima transmission, I30 axles for an I30 transmission.
2. Get the clutch, throwout bearing, and pressure plate out of an '00-'01 Maxima (PM DAVEB for a good price). They won't be any more expensive than the '95-'99 parts, and they'll be a ton better.
3. If you can, get the clutch master and slave cylinders new.
4. Keep the .org posted every step of the way!
Labor shouldn't cost you more than around $1500.
Old Jan 22, 2006 | 09:27 AM
Guinader's Avatar
I have a extra one, (but is not mine anymore) let me explain.
I have a manual trans in my car and one being rebuild the kid who is doing the rebuild will install the rebuild on mine and will keep the old one (he will rebuild that one and sell it here probably... (maybe ebay) this will happen probably in the next 30 days.
I just wanted to put this out so people get some interest...
Old Jan 22, 2006 | 12:45 PM
matts95max's Avatar
I just bought a 5spd max. which makes 2 for me. I swapped trannies from my old max to the new one and im parting out my old 1. so I prolly will have some parts you can use.
Old Jan 23, 2006 | 07:57 PM
iceman82's Avatar
thanx for all the info guys
Old Jan 23, 2006 | 09:50 PM
tavarish's Avatar
fwd gone rwd cr00
buy another car for your wife while you're at it...you wont want to teach her on your brand new 5spd maxima...i should know.
Old Jan 24, 2006 | 09:51 AM
jvienneau's Avatar
Missing 2nd and 4th sounds like a solenoid issue since I believe they both use the same one. Are you getting any codes? Might be cheaper to fix the one you have.
Old Jan 24, 2006 | 09:54 AM
iceman82's Avatar
Took it to a tranny shop they said $2100 to fix
Old Jan 24, 2006 | 10:25 AM
tavarish's Avatar
fwd gone rwd cr00
I had the EXACT same problem, 2200 from Aamco...
it was AFTER the rebuild I decided to go 5spd...
Old Jan 24, 2006 | 10:43 AM
iceman82's Avatar
i was searching through the stickies and found this
http://www.dynomagic.com/maxima/5spd_conversion.htm
this should help if i decide to do this
Old Jan 24, 2006 | 10:45 AM
iceman82's Avatar
thanks I have a friend that has a 5 speed pt cruiser he has offerd to teach her, so she can mess up his,
Old Jan 25, 2006 | 03:35 PM
jvienneau's Avatar
I still wonder what the real issue is. Just because you took it to a tranny shop that wants $2200 to replace it doesn't mean they really diagnosed it. You might want to have someone that knows these trans look at it. I've seen very few that couldn't be fixed in the car.
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
I<3 A32's
Sep 10, 2015 11:07 AM
