grounding points for a 95 max
Old Jan 21, 2006 | 09:16 PM
maxim82's Avatar
i want to do my own grounding kit but not sure where all of the grounding points are, or where the wires go connected need help i want to do this tomorrow thanks
Old Jan 21, 2006 | 09:22 PM
gtr_rider's Avatar
192.168.1.1
http://www.vqpower.com/v2/modules.ph...rticle&sid=149
Old Jan 21, 2006 | 09:56 PM
maxim82's Avatar
thanks alot this really helps
Old Jan 22, 2006 | 08:57 AM
edwardh1's Avatar
are the instructions right?
They say
Installation Process: Grounding Battery/Motor(2) to Chassis
Disconnect your Negative terminal from the battery, and proceed to fit one end of the grounding wire (10") in the sequence, and then secure the other end of the wire to the chassis preferably using an existing bolt. Reconnect and secure your negative terminal and proceed to the next point.
Next point is back over to the Passenger side of the engine compartment near the motor mount while using the same grounding point on the chassis as the previous wire.* This point requires the 12" grounding wire connecting the two points. Use wire ties provided as this wire is located near the pulley assembly which is rotating at incredible speeds.
where it starts with "next point" does that make sense?
Old Jan 22, 2006 | 09:00 AM
gtr_rider's Avatar
192.168.1.1
Next point meaning, Next grounding Point.. fixed it for you..
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
Steven Orozco
Sep 12, 2015 10:41 PM
MaxLife17
Sep 8, 2015 02:36 PM
pktaske
Sep 4, 2015 08:40 AM
