Starting problems lately.
Old Jan 22, 2006 | 03:30 PM
BK1's Avatar
BK1
Hello
This past week, I have had issues with starting the car. It would start, then immediately die. If I push the gas a little after I start it, it will go as usual. The car doesn't cut off or run rough after it starts. It only happens on cold starts (after the car has sat overnight) and doesn't happen on warm starts.
I have replaced the following items: MAF sensor, Coolant Temperature Sensor (the ECU one), and PCV valve (was bad).
The problem is still there. Btw, the car had no problems starting until I put in some BP from a station I never use. Could it be the gas or something else? Anyone else have this problem or can give me suggestions? Thanks in advance for your responses. I've been searching all weekend, maybe there's something I missed.
Btw, I always put in 93 Shell, Mobil, or BP. Thanks again.
Old Jan 22, 2006 | 04:12 PM
njmodi's Avatar
Do I get a tax break?
Clean out the throttle body and idle air control valve... that should help with cold starts.
Old Jan 22, 2006 | 05:19 PM
BK1's Avatar
BK1
Hello
Did you take it out of the car, or clean it while on the car. I've also read that the IAC valve is many pieces that can drop an get lost, is that right or wrong?
Old Jan 22, 2006 | 05:40 PM
Tfvesquire's Avatar
Hi there: I have a nice write up on page 2 of the 4th gen forum. Thread is entitled "car hesitates to start - NO CEL." You also mentioned that you replaced your MAS. How did you know your old one was bad? Sometimes, the wires going to the plug can break and make owners think the sensor is bad. In addition, if you have installed a new one, make sure you clean out the connector and push it in until it clicks tight. Otherwise, it could vibrate lose and that will make your engine stall as well.
Good luck!!
Old Jan 22, 2006 | 05:58 PM
BK1's Avatar
BK1
Hello
Ok, I will check that out.
Old Jan 22, 2006 | 08:33 PM
marco polo's Avatar
I had that EXACT SAME problem, I replaced the ign. relay and the clutch inhibit(auto trans starter relay). problem solved. both relays ran me $18.00 a piece at the nissan dealer.
Old Jan 24, 2006 | 12:11 AM
BK1's Avatar
BK1
Hello
My mechanic removed the throttle body today and cleaned it up properly. The car revs smoother, idle is very stable , problems went away. Let's hope it stays that way. The tiny pinhole in it was very clogged up. Glad I didn't spend more money on sensors.
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
trungg86
Sep 4, 2015 04:58 AM
