Replaced TPS.... wow perfect idle!
Old Jan 23, 2006 | 08:14 AM
bobjohnson's Avatar
Blazin......
Hello all.
I myself as many others have had Extensive Issues/Problems with Idle.
Ive had every EVAP code, every purge valve control china town code..
Ive replaced about 10different sensors including all O2 and knocksensor....
BUT: yesterday i decided to remove the TB and got the dremel out to remove the TPS screws. Replaced the TPS w/one from Autozone.
WOW! my car actually has a warm-up idle now
My car doesnt run so rich on fuel either.
I recommend this for anyone who has idle issues and problems stalling. My car use to stall the first 3 times i started it every-morning. I actually see this engine lasting till 250,000 miles now. at 186,000 now...still blazin...
Old Jan 23, 2006 | 08:15 AM
njmodi's Avatar
Do I get a tax break?
How much is a TPS from autozone? Did your TPS philips-head screws strip as well? I'm having the same trouble... (I was just going to remove mine to play one day, but the screws started deforming)... I need an impact screwdriver...
Old Jan 23, 2006 | 08:17 AM
Linkage23's Avatar
Hell yeah dude! I have had roughidle and the same EVAP codes throwing and I was tryin to determine wha the issue was...I'm doing this today! Thanks for the feedback on your idle issues...it helped me!
-LIEB-
Old Jan 23, 2006 | 08:43 AM
bobjohnson's Avatar
Blazin......
It costed me 70.00 from autozone. Its made by wells and is a remanufactured part. The parts looked identicall except 1 number off (mine was like E16 and the part i bought was like E10...)<something like that..
REMOVAL: Took 2minutes. Get a Dremel. Get a cutting wheel. I have extras of this laying around. Make 1 good cut across the TOP of the philips screw head, make it deep but not all the way down or youll cut the tip off and have to drill out the holes... (i suggest turning the dremel up on high and making 1 fast cut that way you dont loose alot of the tip to lock ur straight screw driver onto). then i think you have only one shot! after that the 2sides of the tip may break off b/c not much is there after making the cut. yes ur using a straight screw driver bc you made the single big cut w/ the dremel.
Ive honestly cleaned every EVAP crap part and replace all my hoses in the past 2 yrs. Ive been needing this part for 2 yrs now and it really feals like a new car...
Old Jan 23, 2006 | 08:45 AM
njmodi's Avatar
Great tips on the removal.. I really need to add a dremel to my tool collection...
Old Jan 23, 2006 | 11:13 AM
bobjohnson's Avatar
Blazin......
Yeah you'd be suprised how much you really use it. I use mine all the time.
I actually used it last night to grind down the center on the grill so my New Gold-Nissan Badge woud sit flush on the grill. 97 grill.~wise investment imo
Old Jan 23, 2006 | 01:44 PM
JeremysBlkMax97's Avatar
Unbelieveable, I really hope this fixes my idle problem also. Did if feel like the car was ever so slightly vibrating on idle, but the second you pressed the gas a little, the vibration smoothed out, and you couldn't even tell? I also am running a little rich b/c I can smell it from the back, and I see carbon deposits on my muffler after about 2-3 days.
Old Jan 23, 2006 | 02:47 PM
konak85's Avatar
bobjohnson, did the evap codes go away? Was there a code fokr the TPS? Glad you solved your problem.
Old Jan 23, 2006 | 06:31 PM
goldtooth's Avatar
wait, why did you need a dremel, cuz ur screws were stripped?, cant I just unscrew it with a screw driver if my screws are good ?
Old Jan 23, 2006 | 06:36 PM
njmodi's Avatar
Try it and you'll see My screws have never been touched since the factory and even with a screwdriver that fits perfectly, I started stripping the head.. you can always try first, but be prepared to get creative.
Old Jan 24, 2006 | 07:40 AM
bobjohnson's Avatar
Blazin......
Not that easy, As njmodistated. Sometimes ya gotta come with ur A-game as they say... I didnt wanna start stripping with a philips and then try it with a demolished head.
JeremysBlkMax97: Dude my car vibrated like a 69cuda... it loped it was getting so bad...even back fired out the intake once i think.
konak85The EVAP Codes went away when i sprayed WD-40 in the canister, cleaned the EVAP purge control valve w/TB cleaner, replaced some hose's and EVAP cleaning. The ECU-Codes may have dissappeared at that time, but it didnt run much better. Now the car has a steady nice smooth idle. Something ive been missing for quite some time now...
Old Jan 24, 2006 | 01:01 PM
tomservo291's Avatar
The EVAP system (canister, vcv behind rear wheel) doesn't affect how the engine runs... it's just a pain because its part of "emissions," so if you have a CEL for it you can't pass inspection. I had to do my canister/vcv three months ago to pass inspection.
Lilchikcadee
May 1, 2019 08:49 AM
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
umnitza
Sep 1, 2015 01:03 PM
doobadoo
Aug 15, 2015 06:43 PM
