New Spark plugs... problem
Old Jan 23, 2006 | 01:11 PM
ryant35's Avatar
I just changed my spark plugs, I got some Bosch Platinums. They didn't have any NKG's in stock. The guy from Auto Zone said they are pre-gapped, but now my car shutters once every few seconds at idle in gear, and a couple of times a minute while at idle in park.
Should I pull them out and check the gap? What should the gap be?
Or should I just go get some NKG Platinums? I don't care about wasting $10 or $20 if I have to trash the Bosch plugs.
Old Jan 23, 2006 | 01:13 PM
Nissan 6's Avatar
Yes get the NGKs, it is your best interest to. The gap is .044
Old Jan 23, 2006 | 01:15 PM
MaximaSE96's Avatar
Maxima Owner
well Bosch is ur problem....they suck....i had an eletrode fall off on a bosch and shoot into an injector....
Old Jan 23, 2006 | 01:17 PM
Dubbya's Avatar
VK56 Inside
Check the gap and make sure all the coils are plugged in tightly. Is there a CEL?
Old Jan 23, 2006 | 01:18 PM
njmodi's Avatar
Do I get a tax break?
wrong plugs
Old Jan 23, 2006 | 01:33 PM
NmexMAX's Avatar
dot dot dot ...
Go to the factory and get Cu's for less than 2$..
Old Jan 23, 2006 | 01:36 PM
JeremysBlkMax97's Avatar
I had heard once that the Bosch sparkplugs were bad for the Maxima, and was told by many others that the only plug to put into our cars was the NGK.
Go get them and be done with it.
Old Jan 23, 2006 | 01:58 PM
ryant35's Avatar
Well I guess there's the proof Bosch plugs suck.
Thanks for the help guys!
Old Jan 23, 2006 | 03:06 PM
Evo's Avatar
Evo
I've been getting increasingly crappy milage lately, and im guessing replacing the spark plugs would help.
Is this a tough job? and is there a tutorial anywhere on how to do this?
Also, anyone know a good place to buy them?
thanks in advance.
Old Jan 23, 2006 | 03:17 PM
njmodi's Avatar
NGK coppers from autozone, NGK platinums from Dave Burnette (look in FAQ sticky for his #).
Tutorial:
1. remove coils
2. remove plugs
3. replace plugs - torque to 15-20ft-lbs
4. replace coils
More details in the stickies (surprise surprise) :
Old Jan 23, 2006 | 03:25 PM
Evo's Avatar
Evo
sorry, just saw the stickies. tutorials for everything, nice.
Old Jan 23, 2006 | 04:59 PM
ryant35's Avatar
Autozone didn't have the NGK's so I got the bosch crap.
It took me 5 different stores to find the NGK's and they didn't even have the platinums.
I'll let you know what happens in 30min.
Old Jan 23, 2006 | 05:03 PM
f550maranello2's Avatar
NAPA has NGK's for like 80$
Old Jan 23, 2006 | 05:50 PM
ewuzh's Avatar
BMW's use Bosch. We use NGK. I'm running NGK coppers. 2 dollars each. I gap them myself to my own specs.
Old Jan 23, 2006 | 06:31 PM
97Se5spd's Avatar
I got the bosch platniums from autozone also. My car started to idle rough at around 500 when in gear. When its in park its great you wouldnt even know its running. Acutally the car drops to idle when im coasting, but I found I can prevent this if I have O/D off. (this only occurs at speeds below 40) Could this be crappy plugs? I didnt check the gap I jus put them in by the way.
Old Jan 23, 2006 | 06:35 PM
njmodi's Avatar
Originally Posted by 97Se5spd
way.
It's not the plugs that are crappy. It's not the right plug for our car, plain and simple. Go get some NGKs
Old Jan 23, 2006 | 07:01 PM
Evo's Avatar
Evo
sorry for the noobness, but are these alrgiht, for a '96 maxima SE? http://cgi.ebay.com/ebaymotors/6-NGK...32491650QQrdZ1
theres a bunch of different NGKs
Old Jan 23, 2006 | 07:07 PM
NmexMAX's Avatar
dot dot dot ...
Check the stickys for the correct ones(part #) we can't do it all for you.
Old Jan 23, 2006 | 07:36 PM
ryant35's Avatar
Ok, I've got my NGK's in and it runs great! And I also check to see if the Bosch plugs were gapped right, and they were pretty close.
So its NGK only!!!!
Thanks for your help everybody!
Old Jan 23, 2006 | 07:38 PM
njmodi's Avatar
So its NGK only!!!!
So now you've passed the first step of Maximas 101... you are offically in charge of all spark plug related threads. Please educate the other whoring your thread and asking which NGKs to use.
Old Jan 23, 2006 | 10:11 PM
99Maxxx's Avatar
yeah, its rather sad that I work at Autozone and still can't get NGK's....I had to go to O'Reilly
Old Jan 24, 2006 | 07:53 AM
clive's Avatar
100% chingon
I recently replaced my plugs and couldn't find NGK anywhere so I put the Bosch platinums in. There seems to be a conspiracy to sell Champions which I wouldn't use even in a lawnmower engine.
The car runs great, better than with the old NGK plats that I took out. No problem.
Old Jan 24, 2006 | 08:09 AM
njmodi's Avatar
Go get some NGKs and it'll run even better than it does with the Bosch..
Old Jan 24, 2006 | 09:58 AM
rdbaron9's Avatar
I just bought some NGK laser platinums from an Autozone, I called ahead and they ordered them for me. I called at 8pm and I could pick them up the next day at noon. I think they were $7-8 a plug, it was either Autozone or Advance Auto Parts... they are all the same to me.
Old Jan 26, 2006 | 03:36 PM
Evo's Avatar
Evo
anyone have a preference between NGK platinum and Iridium?
Old Jan 26, 2006 | 04:02 PM
Bobo's Avatar
Stay with platinum plugs. Iridium are better suited for boosted applications.
Old Jan 26, 2006 | 04:29 PM
Evo's Avatar
Evo
k, thanks.
i thought iridium was better, so i was confused why they were the same price.
Old Jan 26, 2006 | 04:43 PM
NmexMAX's Avatar
dot dot dot ...
I'd rather have Iridium in the bank, not in my engine.
Old Jan 26, 2006 | 07:37 PM
1996blackmax's Avatar
I would switch the first chance I got. I have read many posts with issues related to plugs that were not NGK (Bosch).
Old Jan 26, 2006 | 07:48 PM
Delvin's Avatar
If you can find Denso platinums they work well to. They aren't as expensive as the NGKs.
Old Jan 26, 2006 | 07:57 PM
If cost is an issue, NGK coppers are not expensive either. Change out interval is half.
Gingerheadman
Oct 1, 2015 05:11 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
JoshG
51
Sep 21, 2015 10:41 PM
