Y- Pipe Install Question
Old Jan 23, 2006 | 08:03 PM
djdirtyrice's Avatar
talked to my mechanic and he said depending on the size of the y-pipe (i think the diameter of the pipe coming from the headers) he would have to remove the stock cat converters to fit the pipe and he would have to intall a more heavy duty cat converter to keep the car from failing emissions.
i have the budget y-pipe is that capable of fitting to the stock cat converter?
Old Jan 23, 2006 | 08:09 PM
Dave H.'s Avatar
I'm pretty sure all the y-pipes out there will fit just fine with the cat converter. My budget fit just fine...
Old Jan 23, 2006 | 08:10 PM
95GLEMAXX's Avatar
yes it is and there is only one main cat...but the y pipe removes the 2 precats
i have never heard of having to replace the main cat when puttin in the aftermarket y pipe....
i have the budget y myself with tje stock cat
i hope hes not trying to bs you.....
Old Jan 23, 2006 | 08:11 PM
bobjohnson's Avatar
Blazin......
They all fit fine.... just no 3inch piping man....
njmodi's Avatar
Do I get a tax break?
No need to replace the cat. Yes you lose two pre-cats, but they are only needed when your main cat is still cold and not working efficiently.
The y-pipe should be a direct bolt-on. Just take it to a muffler shop.
Old Jan 23, 2006 | 08:18 PM
MaximaSE96's Avatar
Maxima Owner
or attempt to do it urself with alot of pentrating oil
Old Jan 23, 2006 | 08:36 PM
The Deal's Avatar
How much does he want to charge you?
Old Jan 24, 2006 | 01:19 AM
86maxima96's Avatar
I Broke OT
my budget fit just fine. i did it myself in my garage with a few tools. i would advise you to do it yourself also. most shops around me wouldn't do it because it removes the pre-cats and they didn't want to be held liable for that. changing the cat should not be an issue either. if anything, have him loosen the bolts between the cat and the y-pipe and possible the ones on the headers if you are having a hard time gettin them to budge. the rust down there can be unreal someimes!
Old Jan 24, 2006 | 02:57 PM
165.........................
Old Jan 24, 2006 | 03:35 PM
konak85's Avatar
or with a grinder and torch like me (damn rust )
Old Jan 24, 2006 | 03:53 PM
the mechanic says that when the pre cats come off it could make engine light come on and then i would pass emissions anybody have problems with emissions and there y-pipe
Old Jan 24, 2006 | 06:01 PM
95GLEMAXX's Avatar
nope...just let the car warm up for a while before u do any emission testing
JRod28
Dec 29, 2023 09:56 PM
Cotozic
Jun 28, 2017 08:01 PM
rbuswell
Nov 12, 2016 04:11 PM
stromm
Aug 27, 2015 04:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
