need to match struts, springs, rims and tires
Old Jan 24, 2006 | 10:23 AM
Tygur's Avatar
Read this high speed story. Need to match struts, springs, rims and tires
Thanks for the input.
Old Jan 24, 2006 | 10:48 AM
Tygur's Avatar
bump bump bump
Old Jan 24, 2006 | 10:51 AM
86maxima96's Avatar
I Broke OT
you should not be driving.
Old Jan 24, 2006 | 11:15 AM
Tygur's Avatar
Thanks junior. But if I can't drive fast in the middle of the desert with no other cars around, maybe I should just buy a scooter.
Old Jan 24, 2006 | 01:55 PM
86maxima96's Avatar
I Broke OT
alright, then if you can't even drive safely with noone else around you, i'd be scared to see what would happen on a crowded freeway... just sayin.
31 years old and still drivin like a 16 year old? c'mon...
you and other statistics are the reasons why my insurance won't drop to a reasonable rate till i'm 55.
Old Jan 24, 2006 | 02:16 PM
MaximaSE96's Avatar
Maxima Owner
if it was raining dont drive like a ****...i assume it was because u hyroplanned......and for best ride comfort and performance u should always u matching suspension parts....tires and wheels....there are even slight differences in tires even thought they are the same size...same with wheels....struts prolly not much difffernt if u are using OEM replacemnts but if u are using any kind of performance strut i woudl match them all
Old Jan 24, 2006 | 02:30 PM
MorpheusZero's Avatar
245/45R18s will effectively lengthen your gearing, robbing you of a bit of acceleration. Stock SE tires are 64.3cm high, whereas 245/45R18s are 67.8cm high. That's about a 3.48cm difference, which is about a 5.5% increase in gearing, you might want to go a little lower profile or a little narrower, or just hope that you have really lightweight wheels to soften the blow, but it's obviously not THAT big of a deal.
IIRC, an 8.5" wide rim and 245s are a bit on the wide side for 4th gens, but I believe someone managed to fit 265s under the fenders. My guess is that you might have "scraping" issues under hard cornering, Akumachan has 245/45R17s with Eibachs (like 1.7" front, 1.5" rear drop I think) and his tires seem like they actually hit the wheelwells. This might be able to be solved by rolling the fenders, and he does have a BBK and some spacers under there I believe, so it might be a different story for you.
Can't provide you with much more info than that though, sorry.
Old Jan 24, 2006 | 02:33 PM
If he's using a stock strut, they're gonna blow... 2" drop ain't exactly trivial.
Said he got some illuminas.
Old Jan 24, 2006 | 02:49 PM
MaximaSE96's Avatar
Maxima Owner
i am just saying if he is using an OEM replacement it shouldnt matter...i didnt say he should
Old Jan 24, 2006 | 03:56 PM
ti2tmax's Avatar
Has his VINs memorized
Well, it doesn't seem like your judgment is flawless but illuminas are about the best strut you can buy before coilovers. I paired mine with S-techs and I've got about a 2" drop and it's pretty level too. Not sure how a pair of 18s will fit but given the above measurements and looking at how mine sits, it should fit...
Old Jan 24, 2006 | 04:21 PM
descent's Avatar
Can we get some pics
Old Jan 24, 2006 | 05:29 PM
Stuntin' 101's Avatar
the tallest profile you can get without rubbing issues on your car is a 40 series tire with lowering springs. especially with illumina's since they allow more travel than a non - adjustable strut. the 45 series tire, even if it didnt rub, will also make it much harder for you to stop ( i had them on my car for a week). if your looking to retain some sort of stock ride quality, you made a bad move buying 18" rims. everything you change, will affect your ride. they all play there own part. i will highly suggest you go with h&r springs, since they are only 30% stiffer than stock, as apposed to the 50% most others are.
Old Jan 24, 2006 | 07:03 PM
Tygur's Avatar
Thanks for all of the legit feedback. Sounds like I will get a set of H&R springs and some 40 series tires. I know that I am going to lose some of my comfort with the 18" rims but they look real nice. I really enjoyed my stock Max, I have had it since new that way. I have really contemplated buying a new G35 but I really am attached to this girl.
As for you who are complaining aboiut my SPEED, youi would hate to know about the 140 I pulled on highway 2 in Eastern Washington.
Old Jan 24, 2006 | 07:49 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
are you military, and whats your first sergeants name?
Old Jan 25, 2006 | 04:59 AM
Chocolate_Boi_1Der
the whole 16yr old thing was a point well proven. Proud to say I will be transitioning to ft lewis soon. It means what it means.
Old Jan 25, 2006 | 08:38 AM
Tygur's Avatar
Originally Posted by Cant_Get_Ryte
nice reply, as well as an attempt to edit copied it last night, and you have a response. Proud to say I will be transitioning to ft lewis soon. It means what it means.
What are you talking about? I think you are woofing up the wrong tree. I think that I would have to actually be in the Army to have a first sergent, aka 'daddy'. So sorry to dissapoint. And furthermore, I am 6'4" 280lbs and am not afraid of anyone. So unless you mean that you are planning on comming over to help me install the struts I bought, stand down boy.
Old Jan 25, 2006 | 12:35 PM
Chocolate_Boi_1Der
Internet thuggery, cute. As stated it means what it means. Any other questions?
Old Jan 25, 2006 | 01:35 PM
kormax97
so where is this high speed story... i don't even need to hear it; i can tell the whole story just by the title.
did you happen to erase it because it even sounded stupid to you?
BkGreen97
Apr 2, 2016 05:47 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
