can't start the car, help.
Old Jan 26, 2006 | 05:21 PM
ktranne's Avatar
NOOB
hey guys, I have a 96 maxima. It has bad problem with starting the car. It takes about 20 times for the engine to run. I changed the starter but still same problem. Need help. Thanks for any respond.
Old Jan 26, 2006 | 05:24 PM
NmexMAX's Avatar
dot dot dot ...
Are you turning the key?
Old Jan 26, 2006 | 05:27 PM
ktranne's Avatar
NOOB
yea, about 20 times.
Old Jan 26, 2006 | 05:28 PM
Vagabond's Avatar
Check fuses. Always a good start. Run Codes.
Old Jan 26, 2006 | 05:31 PM
NmexMAX's Avatar
dot dot dot ...
vagueeeeee post
Old Jan 26, 2006 | 05:32 PM
SVI30's Avatar
Got to give more info. When you turn the key, what happens? Starter turn over? of not, any click?
Old Jan 26, 2006 | 05:40 PM
ktranne's Avatar
NOOB
when i turn the key, stater not turn over, just click-click....
Old Jan 26, 2006 | 05:42 PM
NmexMAX's Avatar
dot dot dot ...
Answer the other questions too..
Do you have any codes?
Old Jan 26, 2006 | 06:05 PM
ktranne's Avatar
NOOB
no i did not check for the code because i don't know how...
Old Jan 26, 2006 | 06:07 PM
pmohr's Avatar
No more Maximas...
Read the stickies.
Swear to god, there should be a little mini-quiz when you first start here, that asks questions from the stickies before you're allowed to post.
Old Jan 26, 2006 | 06:09 PM
NmexMAX's Avatar
dot dot dot ...
He's been here longer than you have.
Old Jan 26, 2006 | 06:11 PM
pmohr's Avatar
No more Maximas...
Which is what makes it even worse, having been on here for over a year and a half, and not knowing how to check codes, or how to post descriptively.
Old Jan 26, 2006 | 06:40 PM
NmexMAX's Avatar
dot dot dot ...
Good point.
Back on topic..it could be a # of items.
Starter/ECTS/GND points/CPS/CmPS/Battery/Ignition switch
Old Jan 26, 2006 | 06:46 PM
njmodi's Avatar
Do I get a tax break?
Ignition switch... no.. wait... ya.. ignition switch.
Thanks and have a nice day.
matty's Avatar
Do you hear the clicking inside of the car ?? down by the fuse box kinda ?? Sounds like the Ignition Switch to me. Its a $25 part and takes 10 min to install. Its underneath the steering column. I would try that first thing for sure
-matt
Old Jan 27, 2006 | 09:10 AM
ktranne's Avatar
NOOB
Yes the clicking sounlds inside of the car.Thanks Mat & Nj
Old Jan 27, 2006 | 09:56 AM
Zirafa's Avatar
battery?
10 char
Old Jan 27, 2006 | 10:38 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by Zirafa
battery?
10 char
Originally Posted by NmexMAX
/Battery
kjlouis
Nov 24, 2018 06:09 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
mrgooch
Aug 9, 2015 11:00 AM
kirkhilles
Aug 8, 2015 10:53 AM
