Auto Hesitates under quick acceleration
Old Jan 26, 2006 | 11:04 AM
InsneDrmr's Avatar
I started noticing recently that when I floor the car from a rolling start (at any speed), it has a tendency to hesitate a few seconds without any sign of speeding up, then drop the gears and take off, and it doesnt pull the way that it used to. Also I noticed once in while when floored the RPMs will jump and the engine will rev but the car wont speed up for about 2 seconds, where as before it used to just be an instant thing.
MAF replaced last year
KS replaced last year
Spark Plugs changed out
K&N Drop in filter
Old Jan 26, 2006 | 11:07 AM
njmodi's Avatar
Do I get a tax break?
Sounds like your tranny is
Old Jan 26, 2006 | 11:08 AM
InsneDrmr's Avatar
Well that sucks....Ive been babying it all winter. I havent been speeding around since like october.
Old Jan 26, 2006 | 11:09 AM
f550maranello2's Avatar
check ur trans fluid
Old Jan 26, 2006 | 11:12 AM
NmexMAX's Avatar
dot dot dot ...
Tranny =
Old Jan 26, 2006 | 11:44 AM
InsneDrmr's Avatar
Any other things I should check? or signs I should look for to know that this is the case?
Old Jan 26, 2006 | 11:46 AM
NmexMAX's Avatar
dot dot dot ...
Your tranny seems fubar'd.
Use common sense, and check and smell the fluid, check if there is even fluid in there.
Mine's slipping bad in 2nd and 4th, it's only a matter of time.
Old Jan 26, 2006 | 03:46 PM
InsneDrmr's Avatar
Well I checked the fluid....strangely it came up dry. I just had the 60k tune up done a few months ago. It makes me wonder if they ever put fluid back in.
Is there any recommendations on auto tranny fluid? or does it not make a differance. How much do I need to put it, I dont have a owners manual, so I cant look it up.
Old Jan 26, 2006 | 03:59 PM
darklegend06's Avatar
sounds like my tranny with fuild in it. I try to start off from a rolling stop and it won't go, takes awhile and then goes. I'm doing the swap soon so I got no worries. Just hoping it won't go out any time soon.
Old Jan 26, 2006 | 08:40 PM
InsneDrmr's Avatar
Bump, for some input.
Old Jan 26, 2006 | 08:42 PM
NmexMAX's Avatar
dot dot dot ...
You already have sufficient input.
Adding fluid would seem like the more common of the 5 senses available.
Old Jan 26, 2006 | 08:46 PM
InsneDrmr's Avatar
Well I figured that much out....but I wanted to know if there is any brand recommendations...or do I just throw in any old auto fluid?
Old Jan 26, 2006 | 08:50 PM
NmexMAX's Avatar
dot dot dot ...
Nissan D-matic.
Old Jan 26, 2006 | 09:13 PM
99grnmaxgxe's Avatar
There's a Sticky in the Fluids and Lubricants section on ATF. Check it there. NmexMax, I love that slap smiley.
Old Jan 26, 2006 | 09:15 PM
InsneDrmr's Avatar
alright....thanks
Old Jan 27, 2006 | 11:56 AM
InsneDrmr's Avatar
Well I went and picked up some fluid...and I filled her up. Now shes reading right, but withing a minute of putting in the fluid my SES light came on. I hit it with the OBDII and I got 2 codes, P0443 and P0443. Does that make sense? Why would it produce 2 of the same code. I erased them, and the next time i started the car the light was thrown again. Erased them a second time and left. After about 10 min of driving, maybe less, the light came on again, with the same 2 codes (which are exactly the same). Whats the deal?
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
