digital gauge cluster on a 95
Old Jan 27, 2006 | 02:00 PM
maxim82's Avatar
can this be done?
and what years would fit into my 95 without any modifying the car or the wire harness?
Old Jan 27, 2006 | 02:02 PM
s0ber's Avatar
95-97 only.. and its not digital
ur stuck unless you feel like splicing 100 wires to get the 98-99 gauges to work.
Old Jan 27, 2006 | 02:08 PM
maxim82's Avatar
how about swapping the center console for one that has some real cupholders, what years is the 95 compatible with
Old Jan 27, 2006 | 02:10 PM
s0ber's Avatar
If you swap the entire center dash thing from the armrest up until where the front dash meets, you can swap in a 95-99.. They bolt right up.
Old Jan 27, 2006 | 02:16 PM
maxim82's Avatar
do the center consoles from 97-99 look the same if not whats the difference? which one would you suggest? why?
Old Jan 27, 2006 | 02:34 PM
Tim96I30t's Avatar
95-97 analog/ 98-99 digital/ Unless you know what your doing I would not suggest splicing a 98,99 cluster to a 95. You will need the plugs on the back of the new cluster, a wire diagram, and know how to program correct mileage.
If this sounds like its worth it to you I would research a little more before you mess anything up. Yes they look similar from the front, only difference is in the readout on the speedo one analog one digital, tach,gas,temp are the same I believe.
Old Jan 27, 2006 | 04:04 PM
rteenie22's Avatar
fuel and temp face same direction on 95-7 and are opposite on 98-9
Old Jan 28, 2006 | 12:38 AM
Digitized's Avatar
I prefere the OEM white faced non digital mileage display...
looks better
Miket2006
Mar 1, 2021 03:55 AM
RWCreative
Sep 21, 2015 11:01 AM
Max139617
Sep 6, 2015 06:02 PM
