Brake Light stuck on.......
Old Jan 27, 2006 | 04:16 PM
Mxrider52's Avatar
I support for what?
I got a slight problem with my brake light being stuck on. I drove about 40 miles today with it on.
Ive examined the following places and tested.
The E-brake it self been pulled up and down. Nothing.
Checked behind tires when someone was releasing it and pulling up. It isnt getting stuck.
I even checked the button that makes the light come on when the brake is pulled up and it doesnt go off being pushed in or out.
If anyone has a clue please let me know.
Old Jan 27, 2006 | 04:17 PM
Sharp's Avatar
check your brake fluid..i had the same problem
Old Jan 27, 2006 | 04:18 PM
RA030726's Avatar
I'm nutty for Nissans
you need brake pads
Old Jan 27, 2006 | 04:41 PM
Mxrider52's Avatar
I support for what?
Well I looked at my brake fluid and it was right above min but then I see this little round fluid holder on the right back of the firewall (looking at engine) and it was a bit under min and I have no idea what it is but it says use brake fluid so anyone wanna clue me in on what it is?
Well filled both up and it went off. Thanks to you guys. Yay!!
Old Jan 27, 2006 | 05:01 PM
njmodi's Avatar
Do I get a tax break?
Originally Posted by JSutter
you need brake pads
Great that you topped off the fluid - but as JSutter said - low fluid indicates that your pads are wearing (or there's a leak - which is less likely) - double check them too - you may need to replace them soon.
Old Jan 27, 2006 | 05:59 PM
MaximaSE96's Avatar
Maxima Owner
or he could be waiting for the dreaded battery light to pop on as well
Old Jan 27, 2006 | 06:14 PM
Mxrider52's Avatar
I support for what?
Nope filled up my brake fluid and my clutch fluid which were both on or barely under min and it solved my problem
SVI30's Avatar
This Brake bulb is connected to:
1. The hand brake switch thru a diode
2. The Brake Fluid level switch
3. The alternator output
It is unlikely item 3 is at fault. Pull the connector on #1 and #2 to see which switch is at fault. The circuit diagram is on page 87 (approximately) in the EL section.
Old Jan 27, 2006 | 06:24 PM
MaximaSE96's Avatar
Maxima Owner
just saying it was a possibilty usuallly they come on together
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
