tranny questions??
Old Jan 28, 2006 | 11:40 AM
gle w/o sunroof's Avatar
tranny questions??
I heard it isn't smart to get a tranny flush but is there anything else I can do to it. I'm going to bring it to a tranny shop next week.What should I have them do? oh yea I have 140,000 miles and its auto.
Old Jan 28, 2006 | 12:35 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
So there is nothing wrong with your tranny, and you dont know what to do if anything. Why are you bringing it to a tranny shop? Mechanics love suckers like you.
Are you auto or manual? When the the fluid last changed if ever?
Old Jan 28, 2006 | 12:49 PM
Mxrider52's Avatar
I support for what?
Well he said it not good to do a trans flush so that probably means he got the original fluid
Old Jan 28, 2006 | 12:52 PM
Vlasic's Avatar
hehe guess your right.
gear oil should be changed about every 30k miles. Its very easy to do yourself. Just go to a local autoparts store, get a funnle with a long tube and 4.7 quarts of your choice of gear oil and change it in your drive way.
Old Jan 28, 2006 | 01:43 PM
its auto.no there is somethings wrong. It seems like when it shifts it loses all power and then changes gears. Also sometimes when at a light ill hit the gas and then it will slam into gear and drive off. At WOT it also shifts at redline.I bought the car at 122k and now have 140k but I want to change the fluid and screen and want to know what other things I should change or if i'm going to need a rebuild. any suggestions???
Old Jan 29, 2006 | 02:39 PM
dr-rjp's Avatar
First, Warm up the car for five minutes.
Drain out the old tranny fluid - you can do it yourself. Use a 1/2" socket wrench (or a 1/2" to 3/8" adapter) to open the stop screw. Drain it just like you would your oil. Buy about 3 qts Nissanmatic "D" tranny fluid. Buy a 12oz bottle of Lucas Automatic Transmission additive and add it in between quart #2 and quart #3. (NOTE: please ignore any subsequent posts that mention "Bob, the Oil Guy").
Get a long tube funnel, and fill the transmission through the dipstick tube. The Lucas additive is very thick, so take your time.
What you can do is mix some of the transmission fluid with the Lucas to thin it out.
Make sure that you check the dipstick so that you keep the level close to the "warm" mark (although a little overfilling is OK, contrary to popular belief).
The Lucas will help a lot with the shifts. I got over 300k on my original tranny thanks to it.
Old Jan 29, 2006 | 03:42 PM
should I change all the fluid or only the three quarts.just replace what i take out???
Old Jan 29, 2006 | 04:05 PM
Maxima 504's Avatar
I recently went to a Transmission shop and they told me tha they do not do flushes at all. So with my max being a 96 with 133,000 miles on it they said they would drop the pan and do a service for $89. I bought my max with 90 k and was not sure if thefluid was changed ever. The original fluid was still slighty pinkish, but i was having a little feeling between 1st-2nd geard.
Well they dropped the pan, cleaned the screen, magnet, and changed some filter or screen in the tranny. i asked them if my automatic tranny looked in ok shaped when they dropped the pan, and they said everyrthing looked fine. Now my 1st-2nd shifts I cannot even feel, and the rest of the shifts are the same. Feels brand new.
Old Jan 29, 2006 | 06:35 PM
thats what i was lloking for thanks.tranny service thats what i meant in the first place. thanks guys
Old Jan 31, 2006 | 10:05 AM
dr-rjp's Avatar
Just replace what you take out...which you can determine if you have a drip pan with calibrations on the sides, or, you can calculate the amount in your drip pan as follows:
(1) measure the diameter of the pan.
(2) measure the height(depth) of the fluid in the pan
Multiply the fluid height (H) times Pi (3.14) times the diameter (D) squared, and then divide by 231.
In other words:
Height * 3.14 * Diameter * Diameter / 231
This will give you the volume of fluid in the pan in quarts, and the amount of new fluid to add.
Old Jan 31, 2006 | 10:17 AM
lilmush's Avatar
My Nissan mechanic flushes my tranny and it only costs me a case of Heineken.
Old Jan 31, 2006 | 02:59 PM
damn hook me up ill give him 2 cases.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
Socalstillen
Sep 20, 2015 11:46 PM
pktaske
Sep 4, 2015 08:40 AM
