Those d@mn codes!
Old Jan 29, 2006 | 10:36 AM
7EyesOpen's Avatar
Those d@mn codes!
I keep getting the 0302 code for EGR System Hi/Low Flow. Everytime I reset it, it comes back. Has anyone fixed this problem? What needs to be done? Thanks.
Old Jan 29, 2006 | 11:03 AM
njmaxseltd's Avatar
You may need to clean all the EGR passages to get that code to go away.
Old Jan 29, 2006 | 11:18 AM
njmodi's Avatar
Do I get a tax break?
What ^^^ said. Specifically the EGR guide tube that runs from the EGR valve to the plenum needs to be cleaned and the EGR port on the plenum itself needs to be cleaned.
Old Jan 29, 2006 | 01:41 PM
DragonMaxima's Avatar
Tom do you do EGR cleaning?
Old Jan 29, 2006 | 02:35 PM
njmaxseltd's Avatar
I personally don't, but the shop I'm in sure can. He's a bit $$ though..
Old Jan 29, 2006 | 10:11 PM
7EyesOpen's Avatar
Is this something I can do myself ?
Old Jan 31, 2006 | 03:21 PM
knight71's Avatar
I had this code for almost a month, after I replaced EGR solenoid valve my problem was resolved...others on this forum cleaned Egr passages and that did the trick, try replacing Egr solenoid valve first (easier to do)..part only costs about $60..also this link will help:
http://photobucket.com/albums/v158/evilBIGD/EGR/
Old Mar 2, 2006 | 12:23 PM
MaximaTx's Avatar
Speaking of the EGR sensor...
This really doesn't pertain specifically to the 0302 code, but I can't post a new question (even though I'm registered and logged in) nor am I authorized to search to see if this question has already been answered. So...
Does anyone know the reset sequence for the EGR sensor (and O2 sensor) for a '96 Maxima? After 316,000 miles I finally had to have my transmission rebuilt because it was sending nasty messages to the ODBD II computer. That was over 1,600 miles ago and now some of the sensors are still reading "not ready", causing it to fail the Texas inspection.
Last year I had a similar problem after changing a faulty O2 sensor. I paid Nissan $80 to run it through the necessary drive pattern to reset the sensors. This year when I asked them to do it, they looked at me like I was crazy. "You just have to drive it a little while," they told me. I would think that 1,600 miles is more than "a little while"!
Thanks. Sorry about crashing the thread, but I need help bad!
Old Mar 2, 2006 | 04:47 PM
mjf3232's Avatar
Drive Pattern
I am dealing with the same thing, had an emissions error, replaced the part, but not ready on re-inspection. I found these driving patterns online, use the one specific to your car.
http://lyberty.com/car/Maxima_A32_docs/NTB98-018c.pdf
Old Mar 2, 2006 | 05:42 PM
WhiteMaxima9600's Avatar
I have this same code, egr is really hard to get at under all those hoses and stuff.. Looks like i'll just stare at the yellow light a little longer
Old Mar 11, 2006 | 05:00 AM
MikeinMadison's Avatar
I had this code too, but ignored it. I changed the knock sensor and both front O2 sensors, and the EGR and knock sensor codes went away. ????????????
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
