100k maintenance done
Old Jan 29, 2006 | 11:13 AM
Kolyan's Avatar
first time did it myself. took about 4 hours, easy going, w/ lunch break. changed plugs, fuel filter, air filter, cleaned TB and IACV, adjusted throttle cable, and adjusted idle speed. it's much easier then i though. i had some hard time with fuel filter, but it took my roomate about 20 seconds to pull those hoses off (i couldn't, probably didn't pull hard enough). IACV takes about 5-10 minutes to remove. a tip for changing fuel filter: take air intake out, and get the hoses off with hard pull & twist action. the only thing that i am concerned about is maybe i overtightened the plugs
will also take car to shop to flush coolant and tranny fluid
Old Jan 29, 2006 | 11:17 AM
njmodi's Avatar
Do I get a tax break?
I would just recommend you do a coolant drain and fill and a tranny drain and fill. As long as you do the drain-fills every 2 yrs, then I don't think a flush is entirely necessary.
Good work nevertheless.
Old Jan 29, 2006 | 11:32 AM
Kolyan's Avatar
yeah, thats what i meant. drain & fill
Old Jan 29, 2006 | 02:38 PM
njmaxseltd's Avatar
Don't over look the power steering fluid and your brake fluid. They need to be changed as well.
TKHanson
Nov 24, 2018 01:39 AM
pears
Sep 18, 2015 05:25 AM
Jay556
Sep 12, 2015 05:50 PM
sdotcarter
Sep 2, 2015 09:53 PM
