For those who service their own brakes
Old Jan 29, 2006 | 06:10 PM
natty99's Avatar
Hey guys.....I was hoping you could help either dispel or confirm a rumor I heard regarding servicing ABS brakes:
When you push in the piston using a C-clamp, does that in any way knock the ABS control module out of calibration? I've heard that it can screw it up when you do it that way, though I don't know how else you would get that piston in otherwise. Like what do the 'professionals' do on ABS cars? I've seen this method performed in the how-tos, but I just wanted to make sure.....
Old Jan 29, 2006 | 06:16 PM
NmexMAX's Avatar
dot dot dot ...
I do it all the time and have yet to have a problem with it.
Old Jan 29, 2006 | 06:55 PM
buttonhook's Avatar
remember the back brakes have to twist and push in at the same time
Old Jan 29, 2006 | 07:22 PM
JSMax's Avatar
Sold
Just did my brakes yesterday, and I've got the abs. Used a c-clamp and no problems with the sensor.
I've never heard of that problem before.
Old Jan 29, 2006 | 07:25 PM
MaximaSE96's Avatar
Maxima Owner
same here no issues
Old Jan 29, 2006 | 07:27 PM
JwaxMax99's Avatar
Never heard of this happening, I did my 'abs' brakes twice, no problem.
Old Jan 29, 2006 | 07:40 PM
njmodi's Avatar
Do I get a tax break?
to the no probs yet category...
Old Jan 29, 2006 | 08:16 PM
ti2tmax's Avatar
Has his VINs memorized
Make sure you twist cause otherwise you'll bust your piston, I did that once when I had just gotten the car. Other than that, I've had no problems.
Old Jan 29, 2006 | 08:39 PM
PAREDLINE's Avatar
the ABS sensor is activated and located by the drive axles in the front. Using a C clamp does nothing to that. You should clean off the magnets when you do a brake job. In the back the ABS unit and sender is on the hub itself. The calipers have nothing to do with the ABS electrics.
Old Jan 29, 2006 | 09:13 PM
natty99's Avatar
Thanks guys, you're always a big help!
The reason I thought there was some truth to the rumor was that the ABS system, irrespective of the electronics, is in some way directly connected to the pumping of the brake fluid...so, push the piston in, and you obviously displace fluid, the amount and position of which I thought is monitored by the ABS.
Also, regarding the rear calipers, how does twisting and pushing the piston work if you're using a C-clamp? I mean, once you have the C-clamp on the piston, I imagine it would be very hard to twist it (with your hands?) How do you guys do it?
Old Jan 29, 2006 | 09:31 PM
GKET36's Avatar
you don't use c clamp on rear. The piston has to be turned to retract if i'm not mistaken i think its clockwise.
Old Jan 29, 2006 | 09:43 PM
BigLou93SE's Avatar
Yes, you have to turn the rear piston clockwise to retract it. This can be done using needle nose pliers (which I did with ease, others have problems with this method) or there is a special tool available at auto parts stores that is designed to turn the piston to retract it.
Old Jan 29, 2006 | 09:44 PM
2 Da Max's Avatar
calibration? i doubt it, just make sure you go the cap on the brake fluid off
Old Jan 29, 2006 | 09:49 PM
DcMaN's Avatar
havnt seen you in a while 2damax, what are you too good for us now that u got your cadillac. Did you blow it up yet while replacing the speakers :]. haha j/k how u been
Apr 16, 2020 05:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
