Shaking at HIGH SPEED
Old Jan 29, 2006 | 06:51 PM
jian622's Avatar
every since i had those 2 front tires changed the steering wheel seems to be out of alig while driving on high way at around 70-80 MPH.........do i need a aligment? or is just becuase the front and rear tires does not match ? they are 215/55/16's
Old Jan 29, 2006 | 06:53 PM
Mxrider52's Avatar
I support for what?
Did you get them balanced
Old Jan 29, 2006 | 06:54 PM
NmexMAX's Avatar
dot dot dot ...
Could be a # of things.
Tires need balancing
Alignment
Old Jan 29, 2006 | 06:57 PM
darklegend06's Avatar
had the same problem but it was my brake pads that was affecting it, but that was me.
Old Jan 29, 2006 | 06:59 PM
jian622's Avatar
i had it replaced at a used tire place not sure if its balanced or not.....what i was thinking of aligment.
Old Jan 29, 2006 | 07:42 PM
descent's Avatar
I had this problem too. Take off your wheel and look for this plastic spacer.
You may need a wire brush to clear the grime off in order to see it. Once i removed it no more shaky shaky. Who in their right mind would put plastic in between the wheel and the car...
Old Jan 29, 2006 | 08:24 PM
dko683's Avatar
does it shake only between certain speeds? like 70 - 80? probably wheel balance then.
Old Jan 29, 2006 | 08:34 PM
dukelubas's Avatar
Org Lurker
If the previous owner had aftermarket rims they may have required a centering spacer. That spacer would be made of plastic. It doesn't transfer any weight, it simply helps align the rim to the rotor.
Old Jan 29, 2006 | 08:50 PM
ImmaSquashYou's Avatar
that is correct about the plastic piece. also, go back to the place and tell them to re-balance your tires. If they said that they already have, tell them that obviously its the tires that shaking, either that or put new tires on. They'll glady re-balance the tires for you. if they try to charge you, don't pay a dime. When i have my tires on my aftermarket rims installed, i always say even though i know the answer, if it shakes horrible, i can bring it back to be re-balanced for free right? they always say yes and they jsut do it more carefully because they don't wanna be balancing the tires again. Sometimes they do it quick n mess up somehow, or maybe the machine was off or what not. Anyways, it's most likely the tires need balancing if you just got the tires n started to notice it now
James92SE
142
Jan 2, 2024 09:23 AM
Bonka
Sep 14, 2015 11:18 PM
I<3 A32's
Sep 10, 2015 11:07 AM
sdotcarter
Sep 2, 2015 09:53 PM
