NGK Copper Spark Plugs
Old Jan 30, 2006 | 10:08 AM
blkmaxz95's Avatar
I read a few of the discussions here and noticed I was using the wrong plug. I WAS using Boush spark plugs platnium when I should have been using NGK. Well, the NGK's were gapped to .041. The automotive book suggested .44. However, in another book, .039 - .043. So, what should I have done fellow Max enthusiasts? I started up the Max, let it warm up, did some tuning and zoom. I had power through all the gears. I test drove a brand new Max a few days later and realized, I don't need anothe car. I now know what needs to be done to make the old skool 95 feel and react like the '05. And will cost less. I had unbelievable power when I switched out the plugs. I really don't know what the difference in gap size does but the car does perform better at .041. Any thoughts?
Old Jan 30, 2006 | 10:09 AM
NmexMAX's Avatar
dot dot dot ...
What kind of 'tuning' did you do?
I never gap my plugs (BKR5E's), only check them.
As per the FSm, 0.039" - 0.043" is good (1.0mm - 1.1mm)
Old Jan 30, 2006 | 10:14 AM
blkmaxz95's Avatar
Cleaned the K&N filter, cleaned the TB, added some Seafoam and vroom. However, the idle is a little weird. Used to be 700-750 and now its 600-650. Curious?
Old Jan 30, 2006 | 12:43 PM
RB26DET's Avatar
So did you replace your plugs with NGK copper, or platinum?
Old Jan 30, 2006 | 01:37 PM
cmc82's Avatar
how much difference are these two plugs, is it worth the costs?
NGK GP platinum 7090 BKR5EGP 0.044 DOHC $2.68
NGK Double Platinum 2647 PFR5G-11 0.044 DOHC $11.71
are the iridium any good?
Old Jan 30, 2006 | 01:42 PM
njmodi's Avatar
Do I get a tax break?
Neither of those are the right plugs
Search for NGK copper and you'll find your answer.
Old Jan 31, 2006 | 07:44 AM
ti2tmax's Avatar
Has his VINs memorized
My max came with Denso Iridium platinum plugs, but my budget was too low to replace with them, so I got NGK double platnum which is what all the information I found on plugs said to use. I'm pretty sure even my owners manual said to use platinums. This is another one of those age old disputes which noone can agree on.
Old Jan 31, 2006 | 07:48 AM
blkmaxz95's Avatar
I am using the NGK Copper plug. I looked at the plug itself and it had an "R" on it. Not for certain what that means guys. I would have to say, ti2tmax, another dispute. But, it works and gas is a little better plus more power, probably due to the amount of spark its generating. (hmm)
Old Jan 31, 2006 | 08:30 PM
RB26DET's Avatar
NGK also makes an iridium plug. and though more expensive, it is supposedly, more efficient, and can help make more power.
Old Jan 31, 2006 | 08:40 PM
99grnmaxgxe's Avatar
Spark plugs cannot add any power.
Old Jan 31, 2006 | 08:44 PM
Bobo's Avatar
Iridium plugs are better for boosted applications.
Old Jan 31, 2006 | 08:55 PM
RB26DET's Avatar
If you notice, I did not say make more power, I said "help" make more power. An efficiently running engine has x horsepower. An engine running less efficiently, is losing some horsepower to let us say a less efficient combustion. So if, in this context, the spark plugs were replaced, more of the power inherent in the engine would be available for use. Think of this way, if you were remove a potato from your exhaust, you would not gain horsepower, but you would have more horsepower available.
Old Feb 1, 2006 | 08:28 AM
Jatan's Avatar
http://www.ngk.com put in the car info and it'll show you the OE gap (which is 0.044)
http://maxmods.dyndns.org/index.php?MaximaSparkPlugs
Old Feb 1, 2006 | 09:26 AM
Nealoc187's Avatar
SLOW
I think all of you guys put way too much thought and emphasis on what type of spark plugs you are using.
Old Feb 1, 2006 | 01:43 PM
RB26DET's Avatar
I suppose that if the plugs were replaced regularly, then what type might not be as important.
Old Feb 1, 2006 | 01:46 PM
NmexMAX's Avatar
dot dot dot ...
That makes no sense whatsover.
Old Feb 1, 2006 | 02:51 PM
crazy97's Avatar
I'm guessing he's comparing the coppers to the more expensive platinums.
Old Feb 1, 2006 | 09:31 PM
RB26DET's Avatar
Yes, any new plug would perform better than an old plug regardless of if it was a platinum or an iridium or whatever.
Old Feb 2, 2006 | 09:09 AM
glenmoormax's Avatar
10 psi
http://jime.homeip.net/Plugs.html
this is a good chart to help understand what the plug means and how they can help for certain apps. Since i run nitrous i have a 1 step colder (copper) and a two step colder (copper) plugs, iridium is also a "colder" plug, but the lower the number the hotter the plug. Yes Maximas were designed for a "5" platinum gapped at .044 but i gapped mine at .038 for my application. I use my 2nd colder plug when i spray over a 75 shot... and they are gapped at .035... If your N/A use a hot plug, if your boosted use a colder one.
Old Feb 2, 2006 | 04:53 PM
NmexMAX's Avatar
dot dot dot ...
I use coppers in all my Maximas.
I'm bored....Explain?
Old Feb 8, 2006 | 05:50 PM
dejay99's Avatar
Help with Spark Plugs
I am a new member from Canada who is about to change the plugs in my Maxima for the first time. I already purchased Bosch Platinum plugs before I read the threads. Dealers here want $16 for NGK platinum and $23 for double platinum. Will the Bosch work ok or should I spring for the NGK's?
Old Feb 8, 2006 | 05:57 PM
NmexMAX's Avatar
dot dot dot ...
Get NGK coppers. I pay $1.90 each American for mine.
Old Feb 8, 2006 | 09:17 PM
dannydarkman's Avatar
I got NGK coppers for $8.60 for a pack of four at ebay.ca.
Old Feb 9, 2006 | 04:34 AM
crazy97's Avatar
I currently run copper and can't imagine spending the money for the platinums.
Old Feb 9, 2006 | 05:28 AM
Preet S 22's Avatar
I30"T"
too good to be true?
http://partsbynet.com/ngk-7090-2002.html
Old Feb 9, 2006 | 05:42 AM
C MAX's Avatar
platinum comes with the car stock but a lot of the boosted and nitrous guys use copper to prevent detonation. is there really a difference i cant tell ecept the coppers dont last as long. the correct number for copper plugs that you can get at any autozone or strauss is BKR6E-11 which are copper one step colder part number 2756. if you dont want one step colder for n/a applications i think the number is replaced with a 5
Old Feb 9, 2006 | 05:55 AM
Bobo's Avatar
Get rid of the Bosch plugs immediately! If you can't afford the NGK platinums, go with the NGK coppers (BKR 5E-11).
Do you have Lordco in Alberta? If so, go in there and tell them you have an account and you will get a further 30% discount. If they ask with whom, just say the name of a local large company, eg. any oil company, utility etc.
Old Feb 9, 2006 | 06:48 AM
North's Avatar
Boosted guys run colder plugs to prevent detonation not copper. They run copper because they realize there is no need to spend the extra money.
Old Feb 9, 2006 | 07:46 AM
C MAX's Avatar
uhm where did you get your info copper does prevent detonation read first before you answer
Old Feb 9, 2006 | 09:31 AM
dejay99's Avatar
Thanks for the further input. I'll either go with the NGK Platinum or Copper. Has anyone used the plugs from PartsbyNet.com? $27 for a set of 6 G Power Platinum sounds too good?
Old Feb 9, 2006 | 09:42 AM
Bobo's Avatar
It may be too good because it probably is not the right plug. The OEM NGK laser platinum plugs are PFR 5G-11.
Old Feb 11, 2006 | 08:41 PM
White Shadow's Avatar
Still chugging along...
If cost and durability are not at issue, is there a performance based reason to use copper over platinum?
Old Feb 11, 2006 | 08:48 PM
hotthepotpan's Avatar
Hi All,
Purchased my Maxima 98 with 50K miles in June 2003, I now have over 120K, pls advise what should be done. I have already purchased new spark plugs and fuel filter.
Thanks.
Old Feb 11, 2006 | 09:10 PM
1996blackmax's Avatar
Do the 60K service.
Old Feb 21, 2006 | 02:11 PM
RockfordMax's Avatar
Back from the dead
what is the big deal with Bosch plugs...... A spark plug is a spark plug is a spark plug. What brand you choose should have no difference, just like what metal they use for the electrodes makes no difference.....
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
