Need Help!!
Old Jan 30, 2006 | 02:48 PM
Litowcas's Avatar
Need Help!!
We were takin the shock off the 97 maxima, but the upper strut mount ripped off from the metal ring..... Therefore we cant get the 19mm bolt off the shock because the whole scock rod is rotating..... Does anybody have a way to get it off? fast...?
Old Jan 30, 2006 | 02:56 PM
njmodi's Avatar
Do I get a tax break?
vice-grips to hold the shaft - to keep it from spinning.
Old Jan 30, 2006 | 06:05 PM
njmaxseltd's Avatar
Never use vice grips on the shaft, the mark left from the plier will cause the strut seal to tare causing the strut to leak and fail. Warning notices about this process are usually posted on new struts/shocks or even included in the warranty papers.
Unless your replacing the strut with new units, then go ahead with the vice grip.
Try using a strong impact gun and give short high power bursts from the gun to get the nut loose. Once it's broken loose it should spin off pretty easily.
Old Jan 30, 2006 | 06:35 PM
njmodi's Avatar
Agreed. I assumed that - damn .org mentality of modding is taking over my better sense
Old Jan 30, 2006 | 07:32 PM
Litowcas's Avatar
Thanks a lot 4 all the help guys... the impact gun was the only thing that did the work done.
