runnin lean
Old Jan 31, 2006 | 09:12 PM
99I30lmtd's Avatar
runnin lean
I did the emissions test on the ecm and the cel said i was runnin lean, where should i start (have fuel pressure)
appreciate i t
Old Jan 31, 2006 | 09:16 PM
njmodi's Avatar
Do I get a tax break?
We need the exact code that was reported.
Once you have the code, look in the stickies and you'll find some tips, also search: http://forums.maxima.org/search.php
Old Jan 31, 2006 | 09:37 PM
99I30lmtd's Avatar
Sorry, i did not explain, I have no codes, the test is when you put the ecm in to test mode II, (i think) and then you start the car, then the ecm monitors one of the front oxygen sensors, you can then turn the ecm the clockwise to switch oxygen sensors and if the MIL does'nt light up 5 or more times in 10 seconds on either sensor then you are running lean.
any body know wut else besides change the oxy sensors, check coils and injectors?
thanx for the reply
Old Feb 3, 2006 | 06:45 PM
RA030726's Avatar
I'm nutty for Nissans
well since the car has o2 sensors the fuel mixture relys on good signal from them. older o2 sensors give bad readings. you really should start there.
jmlee44
Oct 2, 2022 02:13 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
aw11power
Oct 10, 2021 04:57 AM
cruce91
Sep 20, 2015 10:23 AM
ajahearn
Sep 19, 2015 03:03 PM
