???'s about Springs and Struts ???'s Help please
Old Feb 1, 2006 | 06:16 AM
dsn111's Avatar
I just purchased a set of ground control springs (adjustable ones)
I got them because my rear section of the car slags downward.....
I have 110,000 miles on the car and I am wondering if I could just put the new springs on the car, or if I should really have to buy new struts too....
ii think by putting the new springs on it will help out with handling, but what I really dont want is to put on the springs and then realize that by rear struts are shoot as welll.........is it possible that my rear struts are needing replacement as well, or do they last longer?
please advise on any suggestions........
thanks,
david
Old Feb 1, 2006 | 07:15 AM
North's Avatar
BUY NEW STRUTS! The coilovers you have will destroy the stock springs in no time, it will ride like crap and be very bouncy since the springs are to stiff for the stock struts.
Old Feb 1, 2006 | 07:58 AM
86maxima96's Avatar
I Broke OT
^^^ good call North! the stock springs, which it sounds like are on their last leg, cannot control the much stiffer and reduced travel springs. they will most likely blow in no time and you will just end up driving with worse handling than before and you will need to do the install all over again, this time replacing the struts and shocks. just do it all right the first time and you will be set.
Old Feb 1, 2006 | 09:26 AM
MaximaSE96's Avatar
Maxima Owner
with GC ur gonna want illuminas or AGXs at the least...
Old Feb 1, 2006 | 12:56 PM
blackmaxx96's Avatar
There's never a day when something's not on sale
Originally Posted by 86maxima96
^^^ good call n00b! the stock springs, which it sounds like are on their last leg, cannot control the much stiffer and reduced travel springs. they will most likely blow in no time and you will just end up driving with worse handling than before and you will need to do the install all over again, this time replacing the struts and shocks. just do it all right the first time and you will be set.
Good info by both you and the "noob".... although, his post provided good information, and was not mis-leading... so why would you call him a noob???
Old Feb 1, 2006 | 01:09 PM
tavarish's Avatar
fwd gone rwd cr00
let him do it...aftermarket springs with blown stock strut....go over the right bump, it's gonna feel like a damn grenade went off in your trunk.
Old Feb 1, 2006 | 01:22 PM
86maxima96's Avatar
I Broke OT
i didn't mean it in an offensive manner. it's just that, kinda like what you said, a lot of people will just say the first thing that comes to minda and talk out of their @ss. but no, i agree with you. what he said was definitely helpful, especially for a noob. i can see how it could have been taken the wrong way. i'll edit.
Old Feb 1, 2006 | 08:36 PM
HomerMAC's Avatar
Donating i30 Owner
http://www.kcmaximas.org/tech/suspension/ changer everythign do it rite.. except for the spring isolators and oter hitnigs u dont need..
Old Feb 3, 2006 | 06:34 PM
RA030726's Avatar
I'm nutty for Nissans
ok ok i sound like a broken record but get some shorter konis in the front. then pick any adjustable strut for the rear along with some sort of upper mount .
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
