idle problems and coollant leaking need help???
Feb 1, 2006 | 08:54 AM
my buddy has a gen 4 95 model about 130 k automatic and now its starting to have all these problems
this is what he said
"my check engine light came on again last night with the error
code "cylinder #2 misfire detected" and i am leaking
coolant...a real slow leak...about 20 oz. every 3 days. so
i am not sure what to do about my car...it is running fine
except that it vibrates some when i am at a stop or red
light."
i can't help him i havn't hads that exp with with 99 anyone have any suggestions??
thanks
Tim
Feb 1, 2006 | 10:30 AM
1. Where is the coolant leaking?
2. The misfire could be a bad injector, plug or coil in Cylinder #2.
Feb 1, 2006 | 10:32 AM
I used to have those problems too, but I fixed them.
Feb 1, 2006 | 11:38 AM
Quote: I used to have those problems too, but I fixed them.
what was the diagnosis and what steps did u take to fix it
Feb 1, 2006 | 11:39 AM
good question about the coolant ill ask and get back to ya
Feb 1, 2006 | 12:08 PM
Its probably leaking from a hose - try to narrow it down first
http://www.jatan.net/cylinders.jpg
Your friend is lucky that its cylinder #2 b/c if the injector is bad then he can easily replace it (check the spark plug first and then the coil pack - easy way would be to swap one of your coil packs with his since you're not having this prob)
Mar 25, 2007 | 01:14 PM
ok i don't want to jack this thread and i know this is an extremely old thread, but i tried to search the org to see if i can find a solution similar to the problem i waz having with my max. It seems as though Tim's friend had the same problem as what i'm currently having, the only thing is that i don't have a check engine light on. I had coolant leak, dripping a little at a time, i'm not exactly sure on how much itz leaking. My idle is much lower than what it used to be, prob. a little less than 1K, and there is significant power loss. But the power loss is only when the car is stopped and not moving, when i go up my driveway and let go of the gas (assuming all driveways are a little slanted up), my car starts to roll backwards (my car is an auto by the way). So has anyone figured out any solutions to this problem yet? I sure don't know what it is, i even took it to a mechanic and he was unsure of the problem too, all he did was adjust the idle screw a little, but the problem persisted a couple days after that. So any advice guys?
Mar 25, 2007 | 01:17 PM
i guess i'll try to change the plugs and clean the iacv, but if theres any other suggestions that would be great.
