GReddy SP2 w/hoseclamp mod on a lakeshore blue max
Old Feb 6, 2006 | 06:55 PM
  #41
maxima_kenny96's Avatar
my custom **** rattles like hell, after I lowered my car....it hits the rear axle 24/7. full tank of gas plus my car load to school every morning....its hell....
Old Feb 6, 2006 | 06:59 PM
  #42
VIP Maxima
thats bad, u need to fix it
Old Feb 6, 2006 | 10:11 PM
  #43
VQuick's Avatar
Chassis Freak
Well I haven't scraped it once, although I'm very careful and don't drive as much as most of you....still bothers me a lot, though!
Old Feb 6, 2006 | 10:13 PM
  #44
Fr33way™'s Avatar
Wild for Width
I can't beleive you haven't nailed that thing on something.
Keep the streak going!
Old Feb 6, 2006 | 10:31 PM
  #45
Maxima99SE's Avatar
will fly for food
yeaaaa you MIGHT want to get that checked out... unless you enjoy rattles and bangs..
Old Feb 7, 2006 | 12:27 AM
  #46
4DRSpeed's Avatar
Project Ruby......
Mine as well
I'm swapping to a SP2 in a month or so.
Old Feb 7, 2006 | 02:18 AM
  #47
happyricefob's Avatar
V^___^V
max w/ greddy sp2 4.5" tip
welding 4" magnaflow #35121 SS tip over TRD exhaust system...
TRD exhaust modified Magnaflow tip completed...
tC tip close up....
both max and tc's tip
how do u guys like it?
Old Feb 7, 2006 | 04:15 AM
  #48
maximariceboi's Avatar
yea..i need to center my exhaust =/
Old Feb 7, 2006 | 07:22 AM
  #49
vsamoylov
tC tip close up....
looks really good man
Old Feb 7, 2006 | 09:41 AM
  #50
Ninos_Maxima's Avatar
be the change u want2C
why dont you guys just weld some hangers on to it so you can hold it up? thats what i did with my exhaust system... its like neatly tucked
Old Feb 7, 2006 | 03:36 PM
  #51
VQuick's Avatar
Chassis Freak
The Greddy can't rotate because of the way it's attached to the cat. Very little play. You can't just force the catback to tuck up; it would twist the cat which would twist the Y-pipe which would put pressure on the exhaust manifold. That's why I was asking about some kind of flange mod. All it would take is the flange on the front of the Greddy being rotated 10 or 20 degrees.
Old Feb 7, 2006 | 08:02 PM
  #52
chillin014's Avatar
thats what i kept thinking, it doesnt sound "nice" to just push the exhaust up and twist everything around.
i feel weird about taking my 500 dollar exhaust to a shop to be cut though.
Old Feb 7, 2006 | 08:40 PM
  #53
VQuick's Avatar
Chassis Freak
Yeah, especially since it's hard to find a shop that will work with stainless steel and preserve the mandrel bends on the Greddy!
Old Feb 8, 2006 | 01:20 PM
  #54
Dooley's Avatar
Based on what is being posted...I'm about to take my new Greddy SP2 to a shop to have it installed on my '97, should I be asking for anything special on installation (I can do the hoseclamp thing...)? Much easier for them to do adjustments when it is on the rack.
Thanks!
Old Feb 8, 2006 | 01:25 PM
  #55
vsamoylov
my advie install it yourself and save some money for toehr mods man. its not liek brain surgery to remove a couple of bolts and take the exhaust out.
Old Feb 8, 2006 | 02:53 PM
  #56
V^___^V
2 14mm bolts on the muffler to b-pipe, 3 rubber hangers.
2 14mm bolts on the b-pipe to cat, 1 rubber hanger.
don't waste ur $$ at the shops...
Old Feb 8, 2006 | 03:49 PM
  #57
VQuick's Avatar
Chassis Freak
If the car has ever seen a significant amount of road salt, I would say take it to the shop because those bolts are often so rusted that the heads will simply shear off. Then you'll have to get them torched anyway. If not, do it yourself, it shouldn't be too bad. But exhaust work doesn't usually cost that much anyway.
Old Feb 8, 2006 | 05:23 PM
  #58
abci30's Avatar
oh noes!!!!1111
i got my budget b pipe installed recently. it hangs low but i don't think it is as low as everyone elses. I used some hose clamps to make it sit a bit higher. I would suggest that if you do live in a city where it snows and salt is used, take it to a shop and get the exhuast installed. I did mine at a buddy's shop for free but we had to heat up those cat bolts a lot. One of them actually snaped off. I would just take it to a shop just to be safe or at least pay a shop to take those cat bolts off or replace them i think midas was charging $20-40 for that
Old Feb 10, 2006 | 09:45 AM
  #59
Dooley's Avatar
Midas threw it on for $50, my cat bolts were nasty (car came from Wisc). No rattles or clangs, sounds mean. The tip is a little left of center though, so I am thinking of applying the hose clamp mod to the right side (facing rear) hanger to pull it up slightly and center the tip.
The Midas guy pulled all the shop monkeys over to look at the installed Greddy, looks sweet with all the shiny SS
Old Feb 10, 2006 | 10:00 AM
  #60
One Crazy Max's Avatar
I don't like how the original poster's muffler sits at an angle after the hoseclamp mod... I like the height of mine but the tip isn't quite centered.
actually my exhaust does not sit at an angle, it was probably just the pictures that i took. and its not that hard to center it you just have to use both hoseclamps to adjust it. oh and i have driven it for about 2 weeks now and it has not burned the bumper yet. i think i just depends on how close you mount it to the bumper, mine is a few millimeters away from it which is perfect for looks and for not burning it. and im getting used to the sound, but i think i need to get headers or something, i want more of a rumble, gonna see what i can do to get some cattmans.
Old Feb 10, 2006 | 10:14 AM
  #61
Originally Posted by ethnic6
looks sexily good... I love ur car's color too... how much did it take u to repaint it?
are you asking me that. well if you are, i had it done by my uncle who specializes in body work, and also had it repainted because some girl hit me in a parking lot. so to repaint alone was about sub-$1000 for both sides, front bumper, rear bumper. the trunk hood and roof werent painted but the car blended perfectly, and in light the paint has a little red in it which is real pretty.
BkGreen97
Apr 2, 2016 05:47 AM
ballerchris510
Sep 23, 2015 08:46 PM
Wareagle92
Sep 3, 2015 07:18 PM
