Code 0510 (downstream o2 sensor max volt monitor fault)
Old Feb 4, 2006 | 09:18 AM
Cosmo459sx's Avatar
Check engine light came on yesterday. This is the code I'm coming up with. According to the manual, the downstream sensor operation (as opposed to upstreams), does not affect a/f mixture or fuel injection. BTW, I did put a high flow cat on about 3 weeks ago, but there were no codes at such time. I know that the downstream does monitor post-catalyst o2 levels, so it obviously seems related. The car has been idling very rough, but based upon what info I have, a downstream sensor monitor malfunction shouldn't cause this. I mean, if I replace it, its just going to do the same thing given the high-flow cat. Correct?? Some quality input would be appreciated.
Old Feb 4, 2006 | 10:34 AM
Cosmo459sx's Avatar
Nobody has experience with this ???
Old Feb 4, 2006 | 11:16 AM
njmodi's Avatar
Do I get a tax break?
Time to replace that sensor. (the o2 sensor downstream from the catalytic converter).
Old Feb 4, 2006 | 03:10 PM
Cosmo459sx's Avatar
I understand that, but what I'm saying is that regardless whether I replace it or not, it is going to throw the same code and keep the Check Engine Light on. Besides, the downstream o2 sensor is just a backup in case one of the upstream sensors are down, then it takes the place of them/it and controls actual ratio. Otherwise, and considering you monitor the performance of your vehicle, you shouldn't have a problem.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Sep 8, 2015 02:36 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
Hailstatejig
Sep 2, 2015 06:52 AM
