Quick Help Please!!!!!!!!!!!!!!!!!
Old Feb 6, 2006 | 09:03 AM
wassum's Avatar
ok so i take my moms car into the dealership to get fixed. they replace the master cylinders on it, since the fluid just leaked out of them. we get the car back and the the brakes are sticking. form 40mph just let off the gas (no braking) the car stopped within 200ft. so we take it back. the try to fix it.
get eh car back works ok untill warmed up and the brakes are still not working right. now weve taken it back and they are telling us we have to replace the calipers. help please!!!!!!!!!!!!!!!!!
Old Feb 6, 2006 | 09:07 AM
MaximaSE96's Avatar
Maxima Owner
to them to replace the calipers on it....they did all that brake work and didnt inspect the calipers....thats should be one of the first things they check...they should do them for free
Old Feb 6, 2006 | 09:41 AM
wassum's Avatar
so they are saying the calipers are sticking and they are gunked up. They want to replace the calipers and only charge for the parts. I told them they should be fixing them for free, and that if there was nothing wrong with the calipers the first time we brought it in there shouldn't be anything wrong with them now.
Old Feb 6, 2006 | 09:48 AM
Swazey's Avatar
so u bring ur car in to get brake work done and when u get ur car back its worse than it was before u brought it in? thats entirely THEIR fault. how could they let you drive the car i that condition? they have to fix the brakes. bring the car back and say you want it fixed right and that ur not gonna pay for it either. theres no reason u should have to pay. if they refuse to fix or or try to charge you, take them to small claims court. stand ur ground. they are the ones at fault here.
Old Feb 6, 2006 | 12:55 PM
clive's Avatar
100% chingon
- Some things here just don't make sense.
"Master cylinders" - there is only ONE master cylinder.
"works ok until warmed up" - what would brakes have to do with the car being warmed up?
If the calipers are sticking, this is something you can easily rectify yourself. Buy some brake cleaner and proper brake grease, take the (front) wheels off, undo the two bolts on each caliper, remove the calipers and pads, use a G-clamp to push the pistons back into the caliper housing, clean up the area nicely using brake cleaner. Clean and regrease the caliper pins (those bolts you took out) with proper brake grease, don't use too much. Reassemble, pump brakes carefully to bring pads back up to the rotors. Test drive.
Anyway it is not a disaster even if you decide to replace the calipers. They are not expensive. It's all in the stickies...
Find a better mechanics next time...
Old Feb 6, 2006 | 01:01 PM
Dubbya's Avatar
VK56 Inside
Pay for the calipers and not the labor seems like a fair deal. This is more work they have to preform because the calipers are no good. Its not their fault and just because they didnt notice it the first time around doesnt make them liable for bad parts on your car.
Old Feb 6, 2006 | 01:02 PM
Dubbya's Avatar
VK56 Inside
Braking systems get hot too. When things get hot they expand. This could very well cause a braking system to seize up. I have seen it before. Mainly on drum brakes that have been adjusted too tight.
Old Feb 6, 2006 | 01:04 PM
Dubbya's Avatar
VK56 Inside
Also I dont think relubing the sliding pins on the caliper is going to fix his problem. Sounds like the calipers need to be rebuilt, which is a time consuming task. Most mechanics wont do it. They just get reman'd calipers and start fresh.
Mar 12, 2020 12:06 AM
NewMax03
Oct 7, 2015 08:27 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
