Have a small leak!!! need help!
Old Feb 6, 2006 | 06:16 PM
walshy's Avatar
I was changing my oil over the weekend and i noticed that there was some build up of either oil/power steering fluid on and around my oil pan. I dont know what side the power steering pump is on, but im guessing the other side. So i checked under my car today and saw 2 small drops on the ground, still to hard to determine which of the two fluids it is. Whatever is dripping its minimal but i want to fix it. What do you guys think? oil pan seal?
walshy
Old Feb 6, 2006 | 07:48 PM
njmodi's Avatar
Do I get a tax break?
clean the area up with brake cleaner or whatever, and then you'll be able to see where the oil is coming from.
Also:
Also: It could be anything from a seal to a bad oil pressure sending unit (those things like like crazy).
Old Feb 6, 2006 | 08:16 PM
MaximaSE96's Avatar
Maxima Owner
did u replace the washer on ur drain plug last oil change
Old Feb 6, 2006 | 09:22 PM
ryant35's Avatar
if you can't tell which fluids they are, put a white piece of paper under the car and check the color.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
bigdogsteve
Jan 31, 2018 04:18 PM
