pics of my E46 xenon projector retrofit...
Old Feb 8, 2006 | 07:05 PM
  #41
MorpheusZero's Avatar
Originally Posted by NCSU_MAX
I believe you are correct - Im almost 99% sure you have to have high beams of some sort to pass inspection (at least here in NC, im not sure if it varies from state to state). I guess the reasoning behind it is if you need to signal to other drivers or maybe safety on back roads
So you're saying that my "high beams" are required to be in the same housing as my low beams, even if they're activated by the same high beam "stalk pull?" They would be aimed the same as high beams... I've decided that I would be annoyed by a dual beam retro because it would never look quite perfect to me, and bixenons are a tad expensive..
Old Feb 8, 2006 | 07:08 PM
  #42
Tatanko's Avatar
Bacon Lover
Gotta pay to play
Old Feb 8, 2006 | 07:19 PM
  #43
NCSU_MAX's Avatar
Maximoneypit
Originally Posted by Tatanko
Gotta pay to play
lol, true though.
Im just saying that im 99% sure you have to have some type of high beams.
Old Feb 8, 2006 | 07:23 PM
  #44
4x4Max's Avatar
Looks really clean, good job. If i was doing a retro, i'd want it to look exactly like that.
Old Feb 8, 2006 | 07:34 PM
  #45
WielkiWaac's Avatar
MaximaDriver
looks good man
Old Feb 8, 2006 | 07:42 PM
  #46
99grnmaxgxe's Avatar
Very nice, hope to see pics of them installed!
Old Feb 8, 2006 | 07:57 PM
  #47
Skiptronic's Avatar
Those are so sweet!
Old Feb 8, 2006 | 09:14 PM
  #48
That's what I've been saying the whole time. They're like high beams. Except mounted under the bumper. They're aimed significantly higher than low beams. They're aimed slightly higher than my correctly aimed high beams. Why is this a safety hazard again... they're functionally identical to high beams, in every sense of the phrase.
Gotta pay to play
I don't see the need to drop an extra $300 just to have redundant lights. A single $30 pair of Hella FF75 driving lights completely demolishes my current high beams. I just ordered some $25 projector fogs to see if I can try and broaden the "high beam," just for kicks.
/rant.
Old Feb 9, 2006 | 05:41 AM
  #49
barrynyc's Avatar
Nice retro.....
What did you use to finish the back and do you have pics of before you finished it. I am almost finished with my HID retro but I do not know what to seal the back up with. I think someone already asked if that was JB weld on the back.
Old Feb 9, 2006 | 05:51 AM
  #50
queenambeach's Avatar
Originally Posted by maximus_96
why did you use D2R bulbs? why waste away the couple hundred precious lumens?
Since when did D2R bulbs have less lumens than D2S???
Old Feb 9, 2006 | 05:58 AM
  #51
Dasyce's Avatar
D2R bulbs have always been produced with a sheild on the bulb.. they were designed to be used in reflector housings. to eliminate glare, part of the bulb has a black coating to prevent light from passing through.
D2S is pretty much the same bulb minus this coating.. D2S are brighter since they are designed to be used in a projector, and the projector already has a shield.
Old Feb 9, 2006 | 07:25 AM
  #52
97vq30de's Avatar
don't forget to post when the lights are installed. very nice.
Old Feb 9, 2006 | 07:56 AM
  #53
Tatanko's Avatar
Bacon Lover
/rant.
Then in that sense, HID's are pointless period. Go with a 9007 conversion and call it day if you don't want a large improvement.
Bi-xenon projectors are in no way redundant, and I paid less than most people pay for single-xenon projectors. If you think they're redundant, you've obviously never experienced them at night.
Come to think of it, I probably paid less for the projectors than you would for single-xenon projectors and the driving lights total. The end result is also better, and looks much cleaner. I have one projector, that's it. Nothing on my bumpers. Much cleaner appearance, if you ask me.
Old Feb 9, 2006 | 08:04 AM
  #54
maximus_96's Avatar
correct, and i think its about 300 lumens or so difference in between the two.
Old Feb 9, 2006 | 10:24 AM
  #55
kingrukus's Avatar
no more maxima...
I used jb weld to seal the back. I was quite surprised how well the color matched with the oem housing. I really don't care how ugly the back looks.
Old Feb 9, 2006 | 10:25 AM
  #56
kingrukus's Avatar
no more maxima...
I defintely will be posting installed shots with cutoff pics as well...all in the spring though when the car has been claybarred/washed/waxed with the stillen front lip.
Old Feb 9, 2006 | 11:32 AM
  #57
ethnic6's Avatar
I know thats definately the case here, cops are real ****s, if they think something looks too "racey" they'll pull u over, best to be safe. cause it'll suck if ur pulled over for ur headlight units... especially after all that work u put into it
Old Feb 10, 2006 | 04:36 AM
  #58
aznxenon's Avatar
Dude, that's very sick. You should do a write up on it.
Old Feb 10, 2006 | 05:17 AM
  #59
|Bijan|'s Avatar
UCF Lexus
nice lights phil
Old Feb 10, 2006 | 09:52 AM
  #60
kingrukus's Avatar
no more maxima...
There is already a write up which I used on VQpower.com.
Thanks Bijan.
Old Feb 10, 2006 | 09:25 PM
  #61
ßaller's Avatar
That's a very nice job you have done. I am debating over mines too, I love the E46 Single Xenon, but I am debating over a single lens setup with bi-xenons. Would your stock E46 Bezels compliment the CCFL angel eyes made for it?
- ßaller
Old Feb 13, 2006 | 09:42 PM
  #62
hollaatchaboi's Avatar
any pics on car yet??
Old Feb 13, 2006 | 10:12 PM
  #63
D-Bo's Avatar
Droppin logs
Those look really nice, probably the first ones that have made me seriouslly think about going to the AE headlights. Be sure to post some cutoff pics.
Old Feb 15, 2006 | 09:59 AM
  #64
kingrukus's Avatar
no more maxima...
- ßaller
I am not sure if the CCFL would fit my setup. If they are made to fit a stock E46 single xenon setup, then it should. I am not bothering with Angel eyes though...I am only a fan of them on BMWs.
Old Feb 15, 2006 | 10:03 AM
  #65
kingrukus's Avatar
no more maxima...
Sorry, no pics as of yet. It will probably be another month before I post pics of them installed.
Old Feb 15, 2006 | 10:57 AM
  #66
BoominChu's Avatar
SHIFT_OUTTA DA MAX
i agree, they are rather ricey, due to the civics, and focus' that now have all colors, blue red, green...
Old Feb 16, 2006 | 06:44 PM
  #67
dbysmax's Avatar
that looks incredible...
Old Feb 26, 2006 | 07:37 PM
  #68
cleanmax's Avatar
those are some of the best ones ive seen
Old Feb 26, 2006 | 08:13 PM
  #69
NCSU_MAX's Avatar
Maximoneypit
wheres the installed pics
Old Feb 26, 2006 | 09:52 PM
  #70
ethnic6's Avatar
seriously! we need some pics!
Old Feb 26, 2006 | 11:10 PM
  #71
arrrghhh's Avatar
yea, install pics would be nice... good to see all the projector HID ppl comin to this thread! at any rate, those look AMAZING, damn dude. i mean who cares if the back looks ghetto, just so long as everything works & it doesn't let water in, right? either way, the front of the lights looks simply incredible, and you will be in awe of the light output! enjoy 'em.
Old Feb 27, 2006 | 09:49 AM
  #72
kingrukus's Avatar
no more maxima...
Haha. You guys need to see what my car currently looks like....layers of salt with no paint in sight. As soon as the weather gets here (end of march probably), and I get a few other mods on, pics will come (with a new thread).
Old Feb 27, 2006 | 03:40 PM
  #73
Northern Maxima's Avatar
I should have come out to see it when we were at ESC but it was so damn cold out!
Old Apr 30, 2006 | 09:39 PM
  #74
kingrukus's Avatar
no more maxima...
Here they are finally installed nearly 3 months later:
More pics here: http://forums.maxima.org/showthread....=1#post4933801
Old Apr 30, 2006 | 09:43 PM
  #75
4DRSpeed's Avatar
Project Ruby......
Very nice. I like the way that looks.
Old Apr 30, 2006 | 09:53 PM
  #76
DR-Max's Avatar
Your max have eyes!!!! Awesome look.
Old Apr 30, 2006 | 09:58 PM
  #77
NCSU_MAX's Avatar
Maximoneypit
that is sick dude, great job!
  #78
kpjg588's Avatar
i definitely want something like this done to my headlights. looks very sharp
Old May 1, 2006 | 07:27 AM
  #79
98MaximaSE4ever's Avatar
Post pics after installation.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
