crank REF sensor?
Old Feb 8, 2006 | 11:56 AM
moogotzskillz2's Avatar
crank REF sensor?
sup yeall. i know its be dissuced SO many times, but i have a startin problem, i know what it is, i changed the Starter to 10 tooth nissan one, and it HELPD alot. but i still have check engine light, and i check it its the CRANK REF one.? does that have an effect.
-moo
Old Feb 8, 2006 | 12:50 PM
crazy97's Avatar
-moo
If youre getting a code for it I would suggest replacing it. I beleive it's located just under the belts, easy replacement. 10mm bolt.
Old Feb 8, 2006 | 01:14 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by ECU Sticky
Diagnostic Trouble Code 0407 indicates a malfunction was detected when...
A) 120 degree signal is not entered to ECM for the first few seconds during
engine cranking.
B) 120 degree signal is not entered to ECM during engine running.
C) 120 degree signal cycle excessively changes during engine running.
Possible causes...
- Harness or connectors
- Crankshaft Position Sensor (REF)
- Starter motor
- Starting system circuit
Perhaps a marginal starter would crank the engine at a non-uniform rate (fast-slow-fast-slow) and disrupt the normal rhythm of pulses from the CPS. This is consistent with the starter motor problems you have recently reported.
Old Feb 13, 2006 | 02:08 PM
bobjohnson's Avatar
Blazin......
BUMP>> I CANNOT find this CPS (ref) sensor anywhere.....can someone help me.
ALSO>> when purchasing this on rockauto.com which CPS (ref) sensor do i get? there are a few (ref) sensors to choose from... im kinda lost.
Old Feb 13, 2006 | 04:43 PM
i30ds's Avatar
Armed and Dangerous
Near crank pully. Remove bolt. Undo connector. Install new one. Clear codes. Nuff said.
Old Feb 13, 2006 | 04:56 PM
crazy97's Avatar
I would go to a local parts store for this, that way if it's the wrong one you can take it back. The sensor you are looking for is the cheaper one of the 2, Around $50 I think. It's tucked behind the belts, take off the splash gaurd on the passenger side of your car and you should see it bolted right into the side of the engine.
TallTom
57
Oct 14, 2025 05:16 PM
TKHanson
Nov 24, 2018 01:39 AM
zmcneely13
Sep 26, 2015 02:26 PM
