engine coolant...any green type is fine?
Old Feb 10, 2006 | 01:00 AM
liloutlaws's Avatar
or are there specific brands i should get?
Old Feb 10, 2006 | 03:51 AM
mzmtg's Avatar
Minister of Silly Walks
Any green type is fine. Just mix it 50:50 with distilled water.
Old Feb 10, 2006 | 04:28 AM
dgeesaman's Avatar
Maintenance Monster
NO
Yes, green, but not just any kind. Take a second and read the ingredients. You need one without silicates. So if you see any ingredients with "silic" in the name, pick up a different bottle. I've been buying mine at Autozone for some time and it's not hard to find it without silicates. The story is that silicates eat water pumps.
Dave
Old Feb 10, 2006 | 07:24 AM
mzmtg's Avatar
http://www.asashop.org/autoinc/june97/cooling.htm
A lot has been written about the role of silicates in antifreeze. Yes, they do help prevent corrosion of the internal aluminum components that are increasingly used in engines. But they also tend to drop out of solution to form solids. As a solid, they can clog the system or damage components such as water pump seals. Some vehicle manufacturers and component suppliers are now recommending low silicate antifreeze. Most get the job done using a limited amount of silicate. A way to further keep solids out of the cooling system is by using distilled water in the 50-50, antifreeze-water mixture. Many municipal systems add small amounts of solids, such as lime, to their water. These solids may serve a function in drinking water, but are best kept out of automotive cooling systems.
Old Feb 10, 2006 | 07:45 AM
Kolyan's Avatar
there are SO many posts about this.......let me save u some time. just buy it from Nissan and u are good to go.
Old Feb 10, 2006 | 09:56 AM
liloutlaws's Avatar
damn your'e suppose to use distilled water? i was almost gonna mix it w/ water from the hose
Old Feb 10, 2006 | 01:13 PM
liloutlaws's Avatar
okay then final question
if i don't do a full flush..is mixing any green w/ any green okay? b/c i have no idea what the old green type of coolant and this will be my first time doing it
Old Feb 10, 2006 | 02:11 PM
mzmtg's Avatar
You can mix any greens together. Just drain the rad and fill with the 50:50 mix and you'll be good to go.
Old Feb 10, 2006 | 07:02 PM
liloutlaws's Avatar
also..do people usually flush w/ tap water? i know like a quarter or 2 of water stays in the engine when you flush it, so do people still used distilled water to flush? I know they use distilled water to mix w/ the coolant..but that's a lot of distilled water i would have to buy to do a flush
Old Feb 10, 2006 | 08:12 PM
Kolyan's Avatar
i know u supposed to use distilled water, but most shops don't. so i wonder how important this really is?
Old Feb 10, 2006 | 08:55 PM
dgeesaman's Avatar
Maintenance Monster
IMO, it's silly to use tap water. It's loaded with all the things you're trying to flush out. Shops should use a closed-loop flushing system - if not, you should find a better shop.
If you want to perform a flush, simply buy 2 extra gallons of distilled (at $.85/ea) and fill the system with water first. Then run the car for a short drive (5+min, enough to open the thermostat), and let the car cool. Drain it again, and this time fill with antifreeze mix.
Since the block drain plugs are nearly inaccessible, this will perform a partial 'flush' and leave a substantially cleaner cooling system. If you simply change the coolant in the radiator once a year from this point on, flushing is really not necessary.
Dave
Old Feb 11, 2006 | 02:00 AM
Kolyan's Avatar
do nissan dealers use distilled water then? when i asked shops like NTB, Midas, Direct Tire they all use regular water.
ps. i just changed coolant 50/50 with water and by accident i dropped about 25ml of ATF in it. this shouldn't be a problem right?
Old Feb 11, 2006 | 01:02 PM
mitch33x's Avatar
please read the stickies before posting...
http://www.forums.maxima.org/showthread.php?t=278600
Old Feb 11, 2006 | 01:32 PM
joew's Avatar
does it open the thermostat if you step on the gas on neutral for 5+min.
Dave
Old Feb 11, 2006 | 02:12 PM
liloutlaws's Avatar
lol never noticed we had a maintenance forum..nice
Old Feb 11, 2006 | 02:20 PM
nismos14's Avatar
§è~® f®ÈÄk
Green is good
Old Feb 11, 2006 | 02:34 PM
dgeesaman's Avatar
Maintenance Monster
Temperature opens the thermostat. It takes several minutes if all you do it idle it, but a little quicker if you drive it around. I'd take it for a solid 10min drive and give it 2 hours to cool with the hood up. That's plenty of time for both.
Dave
Old Feb 11, 2006 | 07:58 PM
liloutlaws's Avatar
sounds good i think i'm ready to do the change, one more question
is removing the thermostat necessary when doing a flush (recommended in haynes manual)? or can i just run the car w/ the heater on?
Old Feb 11, 2006 | 10:28 PM
joew's Avatar
just a reminder, if you are going to flush it with h20 only draining from the rad and adding 50/50 af the final conc. will be about 38% of af. you will need to up the percentage to of af to get the final conc. of 50/50. i am glad someone brought this topic up. i need to change mine. i dont know what the car shop did for me.
Old Feb 11, 2006 | 10:49 PM
liloutlaws's Avatar
good point..i was going to point that out..so we should be pretty much pooring only antifreeze in at that point.
but can someone answer my thermostat question?
and does normal operation temperature based soley on temperature gauge? is engine fully hot by then? or just warm?
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
TheMafia
Sep 4, 2015 08:26 AM
trungg86
Sep 4, 2015 04:58 AM
A32goldylocks
Sep 2, 2015 06:39 AM
