Currently installing aftermarket head unit with ROEM-NIS2
Old Feb 11, 2006 | 03:17 PM
OoTOAoO's Avatar
Basically I hooked it all up, I found similar information in this thread:
http://forums.maxima.org/showthread....oto=nextnewest
And I didn't hook up any of the low level (+) speakers but I had ALL of the other cables hooked up except for the blue one (power antanna), b/c my head unit doesn't have a blue cable.
So I plugged it all in, and my front right speaker started clicking after I connected the car battery, I also tried to turn on the stereo and some of the lights on the head unit were blinking quite strangely (not at ALL normal).
So I disconnected it, plugged int the bose head unit and it worked fine. Anyone have any ideas as to why I was having issues with the aftermarket? I checked over the wires and its wired correctly.
Thanks!
Josh
Old Feb 11, 2006 | 03:27 PM
OoTOAoO's Avatar
ok nevermind now suddenly it decided to magically work
Old Feb 11, 2006 | 10:19 PM
nismos14's Avatar
§è~® f®ÈÄk
Man instead of making 298347982374 threads abotu the same thing:
1) combine them,
2) ask in the appropriate forum (audio and electronics)
Old Feb 12, 2006 | 04:12 PM
OoTOAoO's Avatar
there were only 3 gosh!! :P :P
I made them separate to ease the "searching" vs. 3 questions in one thread, b/c they were different issues
Old Feb 12, 2006 | 04:27 PM
Tatanko's Avatar
Bacon Lover
I know it works now, but I'm curious...
Did you have the frame that holds the radio bolted in when you attempted to use the aftermarket radio the first time around?
Old Feb 12, 2006 | 04:32 PM
nismos14's Avatar
§è~® f®ÈÄk
Three audio threads, all about bose/aftermarket install.... one thread IN THE CORRECT FORUM would have been great
Old Feb 13, 2006 | 05:45 AM
OoTOAoO's Avatar
No I didn't bolt it in at first, I just wired it up adn set the aftermarket head unit on my chair... Which unfortunately didn't work, so I had to have it serviced (CD eject was broken :/)
When I get it back (March 8th) I'm going to take pictures of while I'm doing the install and post a guide on here
Old Feb 13, 2006 | 07:38 AM
Tatanko's Avatar
Bacon Lover
Not bolting it in was your problem. That is why it didn't work. The tiny little ground wire isn't enough to ground the headunit, so it wouldn't work properly. I made the same mistake.
Old Feb 13, 2006 | 07:51 AM
OoTOAoO's Avatar
Weird, at first it screwed up, then the second time it worked fine w/o grounding it by screwing the wire in...
I just tightened all the wires, set it on my seat again, and it worked, was so strange... Too bad I have to wait til march 8th to get the damn head unit back, slow *** best buy service plan
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
melteye
May 16, 2016 12:02 AM
BunkyMaxima
Aug 22, 2015 12:58 AM
MikesChevelle
Aug 9, 2015 11:50 AM
MikesChevelle
Aug 6, 2015 11:36 AM
