Crap-steer at low speeds
Old Feb 11, 2006 | 05:01 PM
LeVeL's Avatar
At very low speeds (<2 mph?) or when standing still, its really hard to turn the wheel (compared to how its supposed to be). It's also a bit rough (jerky kind of). Once I get going though its fine again. What do you recon the problem is? Power steering?
Old Feb 11, 2006 | 06:44 PM
MaximaSE96's Avatar
Maxima Owner
most cars are hard to turn at less than 2 mph....but if ur really concerned check all ur PS lines and hoses and do a fluid change
Old Feb 11, 2006 | 07:19 PM
Garrick's Avatar
What are you an old lady? <2mph lolz. You could also factor in that when you are moving at a normal speed, you have the wheels are already moving and covernig a lot pf ground which makes it easier to turn. When going slow you have to move the wheel while it tries to move forward. Does that make sense, because it made sense when I thought of it.
Old Feb 11, 2006 | 10:29 PM
nismos14's Avatar
§è~® f®ÈÄk
If its noticeable theres probably something wrong, but maybe just low on power steering fluid.
Old Feb 12, 2006 | 11:38 AM
clive's Avatar
100% chingon
Sounds like either the PS pump is not producing enough pressure, or the internal valves in the rack are worn out. There's no whining or groaning from the PS pump when you turn the steering wheel? If not, it's probably the rack valves.
Old Feb 12, 2006 | 01:28 PM
njmaxseltd's Avatar
Originally Posted by LeVeL
At very low speeds (<2 mph?) or when standing still, its really hard to turn the wheel ........It's also a bit rough (jerky kind of).
Check the power steering fluid level and the power steering pump belt tension.
Old Feb 12, 2006 | 06:24 PM
LeVeL's Avatar
Thanks, I'll check it out.
MaximaSE96 and Garrick - I didnt have this problem before so Im sure something is wrong right now.
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
