ABS Light while getting out of the snow!?
Old Feb 12, 2006 | 08:47 AM
euser985's Avatar
i just got my Maxima out of the 2 foot snow storm successfully. it took about 5 minutes but with Gear 1 and the Overdrive button i got it done. For some reason my ABS light came on for the first time and its not going away. this happened while i was reving my engine and was strugling to get out. i don't know how revving your engine has anything to do with your brakes, and exactly why it came on. please help me out guys. thanks!
Old Feb 12, 2006 | 01:34 PM
njmaxseltd's Avatar
Excessive front wheel spin while the rear wheels are standing still will confuse the ABS system and set a fault. It should go away after you drive about a mile or so.
Old Feb 12, 2006 | 02:14 PM
konak85's Avatar
My ABS light is on now after it was sitting for like three months. What could be the problem?
Old Feb 12, 2006 | 02:52 PM
VEvolution's Avatar
I miss my VE
When the ABS system gets confused like that, its not working, right?
Old Feb 12, 2006 | 02:57 PM
Groundz's Avatar
what does the OD button do for you in first or second gear?
Old Feb 12, 2006 | 04:06 PM
Motorhead52's Avatar
I was in a similar situation, trying to get up a VERY slippery hill. By the time I was done the dashboard was lit it up like a christmas tree, including the ABS light! Even nowadays, if i slip and slide enough when i start it the O/D light flashes at me.
I would suggest going to www.phatg20.net and d/l the service manual for your year, there is a section in it regarding pulling the codes out of the ABS computer by grounding one of the pins (L) in the diagnostic connecter.
Old Feb 12, 2006 | 04:33 PM
dariod's Avatar
I had a same problem with my first car 1998 Dodge Neon R/T (piece of junk) when I would go through the machine car wash my ABS light would come on but after a while it would turn off but then again it is Neon.
Old Feb 12, 2006 | 05:08 PM
RA030726's Avatar
I'm nutty for Nissans
the abs light should go out when you restart the car. no worries nothings damaged, but yes the abs will not function when the light is on.
Old Feb 12, 2006 | 08:19 PM
VEvolution's Avatar
I miss my VE
Possibly keep the revs up, I would guess.
Old Feb 12, 2006 | 08:50 PM
eLMo's Avatar
Overdrive just turns off the 4th Gear. He wasn't getting up there so there was no point. That's what he meant by that. If you keep it in first gear you can redline it.
Old Feb 12, 2006 | 09:06 PM
VEvolution's Avatar
I miss my VE
Got it.. So the revs are only kept up in 3rd gear, right?
Old Feb 12, 2006 | 09:49 PM
ImmaSquashYou's Avatar
have no worries, happened to me..i was like crap..i think i messed soemthing up, but i drove it for like less than 1/4 mile on a GOOD day n it went away. so just wait til tomorrow when everything is plowed, should go away
Old Feb 12, 2006 | 10:05 PM
descent's Avatar
this also happened to me doing some mean drifting in the snow last night. I would just restart my car and everything would reset and go back to normal. The abs saved my *** several times on downhills coming towards an intersection
Old Feb 13, 2006 | 12:59 PM
nismos14's Avatar
§è~® f®ÈÄk
There not "kept up". The trans is held from shifting into overdrive (4th gear).
Old Feb 13, 2006 | 02:16 PM
BigLou93SE's Avatar
You'd think after the first close call coming off of a hill you'd learn and slow down...
Old Feb 13, 2006 | 03:25 PM
MaximaSE96's Avatar
Maxima Owner
yea my ABS light comes on after dyno pulls....but goes right off
Old Feb 13, 2006 | 03:31 PM
bhmax16's Avatar
You can always draw codes for the ABS if you want. Hook a cable up between ground and the L terminal on the harness just to the right of the fuses on the left side of the dash (NOT the one you'd hook a scanner up to). The L terminal is the 4th one down from top left. After doing this turn the ignition to the on position. After about 3-4 seconds your ABS light will start flashing the code. Read it in the same manner as you would the check engine light codes (just a series of slow and fast blinks). If you have any questions let me know. Oh and I have a list of all the codes so if you find the code but dont know what it's for post it or PM me and I'll let you know what actions to take for troubleshooting
Old Feb 13, 2006 | 03:41 PM
konak85's Avatar
I didnt undestand this part: "Hook a cable up between ground and the L terminal on the harness just to the right of the fuses on the left side of the dash (NOT the one you'd hook a scanner up to). The L terminal is the 4th one down from top left." Can you e-mail me the codes or direct me to them?
Old Feb 13, 2006 | 04:30 PM
bhmax16's Avatar
Ok, if you pull the fuse panel to the left of the steering wheel (you know where the fuel pump fuse is, all your illumination fuses, etc...) there will be a harness in there just to the right of the fuses. In order to draw codes for the ABS you need to ground one of the terminals in that harness, in this case it's called the L terminal which is the 4th hole down on the left (the harness is vertical, not horizontal). You need to hook a wire up to that terminal from a ground. I find it easiest to use the bolt going into the body of the car attaching the door hinge. Run a wire contacting that bolt to the 4th terminal down on the left in that harness, simply sticking the other end of the wire into the terminal. Once you have done this turn your ignition to the on position and after a few seconds your ABS will start flashing the codes. I don't know how to explain it much better than that I'm a mechanic so this is second nature to me. I don't have the list of the codes online unfortunetely...I have the Nissan FSM and they're all listed in there so that's what I use for reference.
Old Feb 13, 2006 | 07:41 PM
vnphantom's Avatar
Snowy in DC last Saturday, and I had to drive to work. So I shoveled some snow out (not completely), started the car, waited, got snow off my car. The I tried to drive off the parking. The car moved for a few inches, then started to skit.
Some more skitting and I got the car out of the pack of snow ... ^^ smell rubber burning ^^ Well, ABS light in on ^^ I just ignored it and drive to work (about 12 miles away) ABS light is still on ^^ Few more inches to complete the parking at my work place and light turned off ^^ Nice day!
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
maximusrising
Sep 2, 2015 09:55 AM
