?!Clutch Push Button?!
Old Feb 14, 2006 | 04:02 PM
96mAx2fast's Avatar
I have a question. When the clutch is pressed, i noticed that there are two push buttons under the dash, by the clutch. When i press the clutch 1 push button switch pops out and when the clutch is fully pressed down, it pushes another push button switch in. What are these two for? Which one is for the car to start? If you need further explanation, let me know. Thanks
Old Feb 14, 2006 | 04:11 PM
MaximaSE96's Avatar
Maxima Owner
clutch safety switch probably
Old Feb 14, 2006 | 04:15 PM
dgeesaman's Avatar
Maintenance Monster
The clutch interlock switch is the one on the engine side. I believe this is the one verified when starting the engine.
The cruise cancel switch is the one on the drivers side of the pedal assembly.
Dave
Old Feb 14, 2006 | 04:18 PM
VQuick's Avatar
Chassis Freak
Yeah, one is to prevent engine starting without the clutch depressed, and the other is to cancel the cruise control as soon as you tap the clutch (otherwise the engine could rev to redline).
Old Feb 14, 2006 | 06:18 PM
96mAx2fast's Avatar
Thanks alot for the info. If the cruise control one is not plugged, will that prevent my cruise control from working?
Old Feb 14, 2006 | 07:02 PM
nismos14's Avatar
§è~® f®ÈÄk
I am still trying to figure out what size acorn nut I need for this mod. So far No place has had it.
Old Feb 14, 2006 | 07:38 PM
ti2tmax's Avatar
Has his VINs memorized
In mine it looks like the wires would have to be cut. Don't see a coupler/connector there...
Old Feb 15, 2006 | 05:58 AM
96mAx2fast's Avatar
The connector is on a little tab right behind the push button. Why did Nismo14 say this was a mod?
Old Feb 15, 2006 | 06:20 AM
nismos14's Avatar
§è~® f®ÈÄk
The mod is to bypass the clutch switch.
Old Feb 15, 2006 | 06:59 AM
NissanMan97's Avatar
if you bypass the clutch switch will that allow you to put remote start on the car?
B
Old Feb 15, 2006 | 08:19 AM
nismos14's Avatar
§è~® f®ÈÄk
You can put a remote start on without doing that I believe, but yes.
Old Feb 15, 2006 | 08:39 AM
96mAx2fast's Avatar
well, i have remote start on my 5spd. I dont know how they did it though. SO, which one is for the car to start? the one nearest the engine or the one nearest the driver?
Old Feb 15, 2006 | 09:52 AM
I didnt know if you could do it or not anyway. I know the place that put my alarm on wouldnt put the remote start on for some reason i always thought is was because you couldnt.
B
Old Feb 15, 2006 | 10:03 AM
96mAx2fast's Avatar
B
you could physically do it but it is illegal. You have to leave the car in neutral or else it will take off if you leave it in gear when you remote start it. Its very dangerous so alot of places wont bother to do it. It also bypasses the clutch switch because i can now turn on my car without pressing the clutch. Thats not that good because if i leave it in gear and someone. that doesnt know any better, turns the key it will jump forward or backward if left in reverse !!!
Old Feb 15, 2006 | 03:41 PM
VQuick's Avatar
Chassis Freak
I'm pretty sure some pros do remote start for 5-speeds and they have some way to make it know whether the car is in neutral or not, and only start the car if it is in neutral. There was a big remote start thread a while back.
Old Feb 15, 2006 | 07:04 PM
nismos14's Avatar
§è~® f®ÈÄk
Neutral safety switch.
Old Feb 15, 2006 | 08:30 PM
s0ber's Avatar
the reverse/neutral switch can be used to allow the car to remote start if in neutral.
Old Feb 15, 2006 | 09:40 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Whoever installed yours should be shot for leaving it like that. Its unsafe and not good practice.
Of course shameless plug for myself..I would have done it right.
Who did the install?
Old Feb 15, 2006 | 09:41 PM
Pearl96Max's Avatar
The button closer to the firewall is the one to bypass. Either through grounding or via relay.
Pearl96Max's Avatar
what the hell would you need that for? Just ground it.
Old Feb 15, 2006 | 10:23 PM
Ninos_Maxima's Avatar
be the change u want2C
i have never noticed these buttons before
Old Feb 15, 2006 | 10:26 PM
nismos14's Avatar
§è~® f®ÈÄk
I think I'll just wait till I get an RS installed from you.
Old Feb 15, 2006 | 10:57 PM
Pearl96Max's Avatar
Have you ever stuck your head down in the dash by the clutch pedal?
Old Feb 15, 2006 | 10:58 PM
Pearl96Max's Avatar
Good idea NoOb
Old Feb 16, 2006 | 06:21 AM
96mAx2fast's Avatar
I have had this type of remote start for about 4 years. On my 240sx, Rx7 and now on my mAx. Im use to it. Its not a problem for me. My cousin did the install for free. I have a prestige pager alarm w/ remote start, shock sensor(which comes standard), a glass sensor, rear trunk release and my trunk/hood have a switch in case anyone tries to open my hood or open my trunk !!!
Old Feb 16, 2006 | 08:50 AM
dgeesaman's Avatar
Maintenance Monster
Heh, nobody who doesn't know better would ever have my car keys. Period.
Dave
Old Feb 16, 2006 | 08:59 AM
Pearl96Max's Avatar
Nonetheless your cousin should learn how to do it Right AND Safely.
Old Feb 16, 2006 | 09:00 AM
Pearl96Max's Avatar
This is completely FALSE. When done right, your car will not even attempt to start if left in gear.
Old Feb 16, 2006 | 09:10 AM
96mAx2fast's Avatar
Is it safe to put a TV in your dash (you look at your favorite scene in a movie, get distracted, crash and die!!)
Is it safe to get 20% tints(god forbid a black car with no headlights is coming to t-bone you and you happen to be in a place w/ poor lighting)
Is driving over 55/65 safe(you could get a blow out and lose control. You could also get pulled over, get so many tickets, arrive late to work, get fired, not have any money to pay your rent, get your house repo'd, be stranded on the street w/ your family, have your son get sick cause of the cold weather and die!!!!)
Things/actions are only as safe as the person practicing them. I have had my cars done like this for years now and have never had a problem. Can you make it safe for me for free? If so, I would be more than happy to bring it to you.
Old Feb 16, 2006 | 09:16 AM
Pearl96Max's Avatar
Its not the point, when it is possible to do something safely, that should be common practice. All it takes is one time for anyone to leave that car in gear. DOesnt have to be you, even someone just reaching in bumps it and you have a problem.
Would I do it for free? No sorry I would not. If you were one of my customers and you were getting a remote start, then yes it would be included. No offense intended here, but I do run a business and free just doesnt fit into my schedule. With the exception of alot of close friends and family. Although I would be more than happy to explain to you or your cousin how to do this properly. Being that he already installed the remote start I would think it wouldnt be that difficult for him to go back in a change a few things.
Old Feb 16, 2006 | 10:33 AM
s0ber's Avatar
I just did a 5spd swap on my car and have no clutch interlock switch thing on my pedal(been bypassed because the clutch pedal didnt come with it)...
I have the RSX 3.5 which I installed with your help, i'd like to know how you can use the neutral/reverse switch to stop the remote start from starting the car unless it is in neutral.
I've been meaning to figure this out but have been a little lazy, and im scared that if some noob messes with my remote and starts the car its gonna jump forward if left in gear.
Old Feb 16, 2006 | 10:46 AM
Pearl96Max's Avatar
Much easier to explain if you wanna gimme a call...
732-572-1969
732-921-9046
Old Feb 16, 2006 | 10:47 AM
nismos14's Avatar
§è~® f®ÈÄk
Whats the 572 #? I only have the other one lol
Old Feb 16, 2006 | 10:52 AM
Pearl96Max's Avatar
The shop line
Pearl96Max's Avatar
want the fax too?
Old Feb 16, 2006 | 11:08 AM
96mAx2fast's Avatar
Well, thank you for your support. I dont know how this even started because i just wanted to know what the push button was for!!! lol.. Thanks to everyone for the support and explanations. I think i figured out why my cruise control doesnt work.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
doctorpullit
Mar 29, 2016 11:08 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
