Using 2 walbro fuel pumps- intank- in line
Old Feb 15, 2006 | 06:56 AM
i30krab's Avatar
Does anyone know if using (2) 255 walbro fuel pumps like title says will work??
Will it give any insurance against a lean condition under hard throttle with SC and N2O??
Old Feb 15, 2006 | 07:25 AM
Chunger's Avatar
My other car is a Hybrid
It should work. Pumps are not as good "pulling" as "pushing" but it would probably add extra insurance. I have not had any experience with this, though. Maybe someone with some fluids dynamics knowledge could talk more about the pressures.
Obviously if the injectors/pulses are insufficient it won't help....
Old Feb 15, 2006 | 07:45 AM
i30krab's Avatar
Yeah, I read some posts on other sites and like usual they're a mixed bag!
One said he had no problem with both working. He also said he can't figure out how gas goes thru the inline pump if it wasn't on because he couldn't blow air thru it. But it still passed thru.
Someone else said he had to use a by-pass to get around the inline pump if it failed. Go figure!
Old Feb 15, 2006 | 08:34 AM
matty's Avatar
Ive only heard of guys using the Wablro intank and a Vortech in-line. Just incase the Wablro goes out, you can still get home on the In-line. If the walbro intank goes out, and you dont have the inline, your stuck.
Ive never heard of guys using more than one, at any given point. Thats alot of fuel
-matt
Old Feb 15, 2006 | 09:13 AM
i30krab's Avatar
-matt
Yeah but don't forget in a recirculating system unused fuel goes back to the tank, frank!!
Old Feb 15, 2006 | 09:31 AM
SPiG's Avatar
SomePsychoGuy
Unless you are using dry nitrous and an FMU (not a very smart thing to do) I can't imagine two fuel pumps would be necessary unless you are getting close to 600whp.
Old Feb 15, 2006 | 12:36 PM
Chunger's Avatar
The Stillen kit has the inline pump working only when boosting (via the Hobbs switch) so I believe all inlines are "pass through". I believe as long as the FPR (definitely need aftermarket) can handle the "extra" flow and return it to the tank it should be fine.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Forge277
Jun 13, 2016 09:26 PM
