CEL is *BLINKING* randomly....
Old Feb 17, 2006 | 07:41 AM
d00df00d's Avatar
Old enuf to pick his own gears
Changed an O2 sensor this morning, reset my ECU, and started driving, and my damn CEL is blinking at what seems like random intervals... although sometimes it will stay off if I keep my speed constant, and come on or start blinking again when I get on the gas. This happened for the entire duration of my 30-minute commute to work.
I know for sure that I'm supposed to be getting quite a few transmission codes since I still have my auto ECU from before my 5-speed swap, but my CEL always just stayed on.
Any ideas??
Old Feb 17, 2006 | 07:45 AM
danman700's Avatar
If i recall i believe that the blinking CEL while driving is misfiring, now i might be wrong but I had an issue with this a month back and I always figured it was misfire from coil pack problems, I cleaned the coils using one of the methods someone posted here and reset ecu and havent had a problem sense
Old Feb 17, 2006 | 07:47 AM
tavarish's Avatar
fwd gone rwd cr00
you didn't reset your ECU right. it's showing you diagnostic codes.
Old Feb 17, 2006 | 08:38 AM
konak85's Avatar
make sure to reset it properly
Old Feb 17, 2006 | 08:46 AM
Tim96I30t's Avatar
Either multiple misfire or still on diagnostic mode, hope its still on diagnostic mode.
Old Feb 17, 2006 | 08:53 AM
tavarish's Avatar
fwd gone rwd cr00
you can tell if it's a multiple misfire, it's not like it's a subtle thing.
Old Feb 17, 2006 | 08:56 AM
WhiteMaxima9600's Avatar
a blinking cel indicates a misfire, different codes for different cylinders so you will have to pull the codes again to pinpoint which cylinder has a misfire.
Old Feb 17, 2006 | 09:30 AM
d00df00d's Avatar
I really, really hope it wasn't misfires...
I got back in the car earlier, double-checked the screw on the ECU to make sure it was turned all the way to the left (it was), and drove... CEL was steady, as normal. Guess I'll pull the codes again just to make sure.
Thanks for all the responses, guys.
Old Feb 17, 2006 | 11:14 AM
cefiro8701's Avatar
yeah...but its not necessarily a sign of misfiring...
i've been in other maximas that were misfiring but didnt have the blinking cel.
Old Feb 17, 2006 | 01:16 PM
My friend had a blinking cel.....Turns out he had a dropped valve
jmlee44
Oct 2, 2022 02:13 PM
MaxDD
Sep 24, 2015 06:40 AM
homeofbacon
Sep 23, 2015 07:17 PM
JoshG
51
Sep 21, 2015 10:41 PM
ballerchris510
Sep 10, 2015 09:35 PM
