Heater not working?
Old Feb 18, 2006 | 04:27 PM
Xmax's Avatar
Heater not working?
All of a sudden my heater decides to quit working during one of the most coldest days of the year. Subzero temps here in Chicago. I know the blower is working, cuz it does blow air, but its cold. Mind you this is when the car is at normal operating temp. It blows a little warm air when i start moving, but when im sitting at a light or parked, it just blows cold air. What gives? My buddy who is a mechanic told me i might be low on anti-freeze, but i added some and that didn't help. Is there a particular fuse that i should look into that i might of overlooked. Checked the blower fuse, thats good, checked the Airconditioning fuse, thats good. This is starting to bother me cuz it is to freaking cold out. I need warmth.
Old Feb 18, 2006 | 05:10 PM
ManualMaxima's Avatar
5th Gen till she dies!
maybe bad heater core? just a guess?
Old Feb 18, 2006 | 05:13 PM
Maxgig's Avatar
Xmax,
Sounds like you need a new thermostat or there may be air in your system. I think if you flush your antifreeze and change your thermostat that will fix your problem.
Old Feb 18, 2006 | 08:58 PM
nismos14's Avatar
§è~® f®ÈÄk
Pretty good suggestions, but first see if your mechanic friend can test your cooling system.
Old Feb 18, 2006 | 09:56 PM
WhiteMaxima9600's Avatar
I wonder if your heater core is plugged up.. or it could be your thermostat, is the temp needle about half way up between C and H?
Old Feb 19, 2006 | 06:19 AM
deeloc's Avatar
you could be just low on coolant.same thing happend to me in my last car. cold air when standing and some heat while driving. checked that my coolant overflow bottle was empty and the radiator was low. added coolant to proper lever and the heat returned idiling and driving.
Old Feb 19, 2006 | 08:18 AM
Xmax's Avatar
Yup needle is is half way between C and H. I filled the overflow bottle, and that didn't help either. Im not sure if the thermostat went bad cuz with this cold weather, it could be just the cold air keeping my engine from overheating. Ill prolly take a look at it when the weather is a bit nicer to work on my car.
Old Feb 20, 2008 | 02:35 PM
apollyon's Avatar
my 96 max is doing this excate thing, a friend said something about it being a rip in a diaphram or something like that?? all i know is it works fine at above 3000 rpm but as soon as i go lower its cold.
Old Feb 20, 2008 | 02:47 PM
2da mizzax's Avatar
why bump a 2 year old thread. you already asked on a diff one.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
