Fuel INJ Sys Right bank lean CEL
Old Feb 21, 2006 | 01:35 PM
lancems007's Avatar
This code, 01-15 just came up on my 97 Max SE 5 speed. I was wondering if anyone has had it happen and has a suggestion and solution.
It's the only code coming up. My car has 123,000 miles on it. Any ideas?
Thanks,
Lance
Old Feb 21, 2006 | 02:02 PM
Trajiksmax's Avatar
Proud Maxima Owner
Right bank is Cylinders 2,4,6. (Front of Motor) Check all the Injector harnesses. Put a screw driver in your hand hold the flat head end against the Injector while the car is running and the handle to your ear you should hear ticking noise if the injector is working correctly. Also pull the plugs out and inspect to see if a cylinder is running more lean than the others.
Question: Have you changed your fuel filter lately?
Old Feb 21, 2006 | 03:44 PM
lancems007's Avatar
I never changed the fuel filter. That may be a good idea.
Old Feb 21, 2006 | 06:45 PM
wynnsmaxima's Avatar
or you could ohm out the injectors to find out if they are bad look for spec. in FSM
Old Feb 22, 2006 | 05:15 PM
nabeel19's Avatar
hmm, if its really one of thee injectors - you are in luck (kind off), its easier to pull out the front (2,4,6) injectors, for the other three you have to take the manifold out. Yeah do change the fuel filter...
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
hayne
Oct 5, 2015 11:53 AM
