EGR Cleaning
EGR Cleaning
This may or may not be posted already but, I have the 0302 code (i think) for "low or excessive egr flow". Does that mean the egr valve is stuck or can I clean it out? EGR valve is like $200 bucks and it really does nothing as far as effecting engine performance so is it worth cleaning or replacing? Please help.
I had this code for almost a month, EGR valve is not the problem, problem turned out to be (for me at least!) was Egr solenoid valve, others on the forum cleaned out their entire Egr related tubes, and that did the trick, I would first replace this part (easy replacement) first to see if the code goes away..here a some previous posts relating to this code:
http://forums.maxima.org/showthread.php?t=393527
http://forums.maxima.org/showthread.php?t=350528
http://forums.maxima.org/showthread....50&page=1&pp=3
Egr location guide:
http://photobucket.com/albums/v158/evilBIGD/EGR/
EGR troubleshooting guide:
http://img52.photobucket.com/albums/v158/evilBIGD/EGR/
EGR are does have an important role in Engine performance. Hot unburned exhaust gases need to be utilized to the the fullest to get better mileage and performance. EGR helps to keeps your engine and exhaust temp within optimum temp, so its good to have a working EGR
I've got the code too. I'm going to start with cleaning.
Originally Posted by mzmtg
Not quite...but close.
How did you clean it?
or better yet... Remove it for cleaning.
I took a look at it and theres all these tubes and clamps holding everything together...
and Which one are you soposed to clean? theres soo many tubes.
Originally Posted by shadyonedeath
Sry for bump, but i need this fix.
sounbwoy had a good thread on this with good pictures too:
http://forums.maxima.org/showthread....&highlight=egr
Apr 16, 2020 05:15 AM
fx4five
Oct 1, 2015 04:58 AM
