Trunk question
Old Feb 24, 2006 | 12:48 PM
oddball86's Avatar
Trunk question
How does one remove the tension bars for the trunk? You know the things that keep the trunk lid up when its open?
Old Feb 24, 2006 | 02:12 PM
ShRapNeR's Avatar
i used a hacksaw and cut mine out.
Old Mar 1, 2006 | 07:40 PM
oddball86's Avatar
was the hinge fro the lid then looser for you?
Old Mar 1, 2006 | 09:09 PM
nfo184's Avatar
why do u wanna remove it??
Old Mar 2, 2006 | 02:30 PM
nfo184's Avatar
how are u going to hold your trunk open then??? and also is that what always makes the rattle with bass???
Old Mar 2, 2006 | 05:33 PM
nismos14's Avatar
§è~® f®ÈÄk
Your trunk will not open when you use popper on the keyfob and on the door. You'll have to start using the key and pulling up hard on the spoiler for it to open. The bars cause the opening of the trunk to be quick and easy. They produce counter weight on the arms of the trunk to force it up as you pull it up
Old Mar 2, 2006 | 06:13 PM
aih98max's Avatar
scoobystoned...
those bars do rattle when you have subs in the trunk. my two 10's rattle the **** outta them. does anybody know how to make that stop?
Old Mar 2, 2006 | 06:45 PM
nismos14's Avatar
§è~® f®ÈÄk
Bend them a little. I had removed my bars then I put them back in because I was going to put hood struts in there but decided against it in the end.
Old Mar 2, 2006 | 06:54 PM
MaximaSE96's Avatar
Maxima Owner
u could always do the blown hood strut trunk mod
Old Mar 2, 2006 | 10:51 PM
nfo184's Avatar
hows thatwork lol ? that just sounds bad lol .......yea its madd annoying with 2 12's .....even with just the one kicking.....
Old Mar 6, 2006 | 06:30 AM
nfo184's Avatar
where do u bend the rod at??? or any other suggestions?
Old Mar 6, 2006 | 01:24 PM
nismos14's Avatar
§è~® f®ÈÄk
Just bend them apart. You don't need alot of force to do that.
Old Mar 6, 2006 | 03:38 PM
aih98max's Avatar
scoobystoned...
really? does it make the trunk not open as easily?
Old Mar 6, 2006 | 03:46 PM
Trajiksmax's Avatar
Proud Maxima Owner
I used a piece of heavy duty foam (black stuff) and put a piece between the bars. Used electrical tape to secure. Yah it's getto but it worked.
Old Mar 6, 2006 | 05:04 PM
1996blackmax's Avatar
Hey don't worry about ghetto. I have actually stuffed rags in some spots to get the rattles to stop. Those darn A-pillars are now very quiet .
Old Mar 6, 2006 | 05:16 PM
aih98max's Avatar
scoobystoned...
i noticed you have a very good system in your car. i have 2 10 inch kenwood typhoons. does your trunk rattle all around the car on the outside? mine does way bad. is there a way to stop this>?
Old Mar 6, 2006 | 05:39 PM
nismos14's Avatar
§è~® f®ÈÄk
I'm sure his trunk rattles a TINY bit, but when he gets his SE-R (hint hint, Juan, go test drive the 6 spd SE-R and you will be in love) I'm sure he'll deaden it to death lol.
Old Mar 6, 2006 | 07:03 PM
My trunk is actually pretty quiet, but I still get a little rattle when turned up loud. Probably just some paneling though. If you are standing outside, and the windows are closed, it sounds pretty quiet. The small rattles are only heard from the inside. I have used a bunch of Dynamat on the trunk floor, some on the side panels (wherever I could stick it), and a good amount on the trunk lid. All this did make a very noticeable difference. I have already done the front doors as well. I still have some left to do the rear doors at a later time .
I would love to get that ride Parag, it is just a room issue with the kids and all. Funny thing is that I was discussing that issue with my wife earlier today. Your SE-R is one sweet ride, now you just need to get that CD7000 put in there . Oh and I know your saying no sub, but in time you will come around .
Old Mar 6, 2006 | 07:09 PM
95SEfreak's Avatar
this blown hood strut mod how is that done both mine are blown on my hood and i want to get two new ones is there a write up? I read about it somewhere
Old Mar 7, 2006 | 06:31 PM
nismos14's Avatar
§è~® f®ÈÄk
You sure you couldnt fit a coupla kids in the back? It is an amazing car man.... amazing.... i love it. They are VERY quick, and absolutely gorgeous... Either way, I'm sure you'll make the right decision.
As far as audio goes, PROBABLY cd7000/cd5000 + germaniums powered by the arc amp and then possibly a set of coax in the rear doors, and leave the stock 6x9 subs in the rear deck powered off the stock amp
Old Mar 7, 2006 | 07:10 PM
Sounds like you are going to have a very nice setup .
Old Mar 7, 2006 | 07:17 PM
My mod for a while was my vice-grip. I finally paid around $40 dollars for a pair at Pepboys. No lifetime warranty anymore, but I don't care. Man I will never go back to my vice-grip mod .
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
Socalstillen
Sep 26, 2015 12:01 PM
