Turn signals work, hazards don't. Why?
Old Feb 25, 2006 | 05:23 PM
nismos14's Avatar
§è~® f®ÈÄk
So about a year ago I tried doing the alarm buzzer mod. It seemed to work the way I had it wired for about 3 beeps or so, then it started to not work. The buzzer just stopped buzzing. I think I had the horn grounded to the chassis which caused some kind of short. Where do I look for this short?
It's very strange, turn signals work fine, but when the hazards go on they do not work, and the turn signals do not work at that time either of course.
Any suggestions?
Old Feb 25, 2006 | 05:42 PM
Trajiksmax's Avatar
Proud Maxima Owner
Does it keep popping the 10A fuse?
Old Feb 25, 2006 | 05:53 PM
nismos14's Avatar
§è~® f®ÈÄk
Nope fuse is fine.
Old Feb 25, 2006 | 06:10 PM
pmohr's Avatar
No more Maximas...
How about the relay? Lower row, third from right in the relay box in the right side of the engine bay.
Old Feb 25, 2006 | 07:43 PM
njmaxseltd's Avatar
Flasher relay, it's located under the dash.
I believe it controls both the hazards and the L/R flash.
Old Feb 25, 2006 | 08:45 PM
descent's Avatar
on the subject of relays...is there a cigarette lighter relay? mine has been dead since i blew it out plugging an inverter and vacume into it and i cant fix it =(
no fuses are blown under the dash
Old Feb 25, 2006 | 09:04 PM
DennisMik's Avatar
There is no relay for the cigarette lighter. the 15 amp fuse (fuse #6 i think) goes straight to the cigarette lighter via an orange/blk stripe wire. i would pull out and check the lighter socket for over heated/burned connections on both the orange/blk wire and the black ground wire where they connect on to the lighter socket.
Old Feb 25, 2006 | 10:22 PM
descent's Avatar
i already replaced the socket itself from a guenine nissan oem parts site online. the plug looks good. i put a volt meter on it though and there is no current.
Old Feb 26, 2006 | 12:26 AM
nismos14's Avatar
§è~® f®ÈÄk
Have not tried this one, but if its bad would it cause the turn signals to be bad too?
Old Feb 26, 2006 | 12:28 AM
nismos14's Avatar
§è~® f®ÈÄk
I tried and replaced this one, no workey still..
On a side note, Tom, I have some major creaking and crap in my suspension. I can't for the life of me figure out what it is. Is this something you still can take a look at, and/or recommend what may need replaced? TIA.
Old Feb 26, 2006 | 11:11 AM
RA030726's Avatar
I'm nutty for Nissans
im thinking BCM
Old Feb 26, 2006 | 11:25 AM
nismos14's Avatar
§è~® f®ÈÄk
Ya I guess I have to get in there and get the damn serial off of it... blah. I bought one before and it was the wrong one. Thanks for all responses so far fellas.
Old Feb 26, 2006 | 11:56 AM
DennisMik's Avatar
The full circuit is that the cigarette lighter fuse gets its power from the ignition switch when it is in the ACC or ON positions. so if you are not reading any voltage in the cigarette lighter when the ignition switch is in ACC or ON, then you will have to check wiring backwards from the cigarette lighter.
my fsm for my 97 does not show any connections in between the fuse and the lighter socket. what i would do is pull the cigarette lighter fuse out and measure for voltage in the fuse panel where the fuse goes. don't forget to turn on the ignition switch and check both fuse leg connections. with the fuse pulled out, there will only be voltage on one of the 2 legs.
if you have voltage, check the fuse for continuity with your meter. if the fuse is good and you have voltage on one side of the fuse socket, then my guess would be that you have a bad wire connection on the back of the fuse panel (the orange/blk stripe wire).
if you didn't get any voltage when checking the fuse panel, again i would suspect a bad connection to the fuse from the ignition switch.
Old Feb 26, 2006 | 04:31 PM
njmaxseltd's Avatar
Interesting.....
Sure, just schedule an appointment with me. 551-427-5157
Old Feb 26, 2006 | 04:45 PM
nismos14's Avatar
§è~® f®ÈÄk
Interesting.....
I will give you a call one afternoon. Btw do you work on Saturdays? Atually in that case what are your hours?
trasmadean
Feb 1, 2017 08:20 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
beboski
Aug 16, 2015 05:23 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
