Quick Question
Old Feb 28, 2006 | 03:46 PM
Brukaz's Avatar
Quick Question
Hey guys, I want to put leds in my gauges but I don’t really know anything about them. If u guys can answer these questions for me I would really appreciate it.
1. What size and type of leds do I need?
2. How many leds do I need to buy for my gauges?
3. Which is the best website to order the leds from?
4. what do I need to do to get my needles to light up as well?
Old Feb 28, 2006 | 04:48 PM
Brukaz's Avatar
Anyone?
Old Feb 28, 2006 | 06:24 PM
Brukaz's Avatar
Come On, PLEASE!
Old Feb 28, 2006 | 06:36 PM
99grnmaxgxe's Avatar
http://www.petah.org/maxima/gauge.htm
http://www.geocities.com/amixam69/nissan/dash/
http://www.richardjasaitis.com/MaximaDash.htm
You're Welcome, next time read the stickies, that's where I got those all from.
Old Feb 28, 2006 | 06:57 PM
Brukaz's Avatar
Originally Posted by 99grnmaxgxe
Thanks Alot! Im sry for being a pain in the ***
Old Feb 28, 2006 | 07:02 PM
NP, you weren't a PITA
Old Feb 28, 2006 | 07:48 PM
BlackMaxdout's Avatar
ummm...usually you can't just buy any LED and have it work, because they usually only come in some voltages, and they burn up easy. The electrical rule of thumb is V=IR....where v is voltage, I is current, and R is resistance. Take the voltage your car produces, substract the voltage rating on the LED, and that is the voltage that you need to cancel out with a resistor. Solder the resistor to the positive side of the LED and give it juice. Good luck.
Old Feb 28, 2006 | 08:35 PM
Brukaz's Avatar
I was looking on ebay and i say these 5mm leds, but some had 10,000 mcd F/R 20,000 mcd F/R 40,000 mcd F/R and so on. What do they mean by mcd F/R and what is the difference between the numbers?
Old Feb 28, 2006 | 08:42 PM
MCD is the brightness rating. I forget what it stands for. The higher the better, but it also means you'll pay more for each bulb. I think that F/R means that they are focused. LED's shine in a certain pattern. Focused means that they will shine in a 35 degree (or other variation) arc in front of them. You can get focused, and the other type which emits light in a bigger arc to cover more area with light. I think that you could use focused if you want too...it'll make the gauges even brighter.
Old Feb 28, 2006 | 09:06 PM
Brukaz's Avatar
would buying the focused leds have a greater chance of showing hot spots or not lighting up the whole gauge area?
Old Mar 1, 2006 | 05:48 AM
it's a possibility. You can always get the other ones...and they will still be brighter than regular 194 light bulbs.
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
