Starting problems
Old Mar 1, 2006 | 12:35 PM
Umass021's Avatar
Starting problems
I went to go start my car this morning and it wouldn't start. It started to turn over then it starting making a whinning sound. I tried it a few more times and all it did was whine. I ended up poping the clutch to get it started and then let it run for about 20 minutes. I then re started it and it turned over for a second then the whinning noise again. I tried again and it started. I had to try quick starts to get it to catch it seems like. I had the starter done around a year ago. What do you think it is? I am hoping not the flywheel because who knows how much that cost. I had the tranny rebuilt around 7 months ago and I would think the resurfaced it but I don't know. Does anyone know what my problem is?
Old Mar 1, 2006 | 01:37 PM
Trajiksmax's Avatar
Proud Maxima Owner
Could be a bad Battery or Alternator. Is it the battery original? I live in NH and it's been colder than a witch's *** that also could be a contributing factor.
Old Mar 1, 2006 | 01:57 PM
svetlin55's Avatar
could be bad conection btw battery&starter
Old Mar 1, 2006 | 02:40 PM
Umass021's Avatar
No it isn't that. I have a full battery and the alternator is fine.
Old Mar 1, 2006 | 03:46 PM
Mishmosh's Avatar
You need to figure out where the whining is coming from. The whining only occurs with the car not running and during cranking?
Old Mar 1, 2006 | 08:36 PM
DJ98MAXSE's Avatar
how many miles on the car?
Old Mar 2, 2006 | 12:49 AM
Umass021's Avatar
168,000. Yeah the whinning only happens with trying to start. I replaced the starter over a year ago.
Old Mar 2, 2006 | 01:50 AM
joaquink's Avatar
¿Hablas Español?
There's really only 1 solution for this issue...
Old Mar 2, 2006 | 07:39 AM
DJ98MAXSE's Avatar
The best thing to do is have it diagnosed at a Nissan Dealer. That way you'll know exactly what the problem is, and can figure out if you can do the work youself and same some $. Going on guessing and replacing parts which might not need replacement can get expensive and still not solve the problem.
Old Mar 2, 2006 | 07:44 AM
speed racer's Avatar
I would check the grounds. Also there was a thread not too long ago that showed that placing a ground on your starter and transmission helped with startups.
Old Mar 4, 2006 | 11:23 AM
Umass021's Avatar
Well I just got a call and the new starter is in. They said the total is $250. Do you think that is a lot for a starter?
Old Mar 4, 2006 | 03:58 PM
Trajiksmax's Avatar
Proud Maxima Owner
Sounds about right for an OEM starter from Nissan. Should be a core charge of about $60.00.
Old Mar 4, 2006 | 03:59 PM
Mishmosh's Avatar
If that includes installation, that is about right. If not, then they are charging you what the dealer would for the part. You can get a lifetime warranty rebuilt from Autozone or others for about $150 more or less. Aftermarket new ones cost about the same.
Old Mar 5, 2006 | 03:59 PM
Umass021's Avatar
Yeah that was for the part and install. So far so good with the starter. This is my secoind starter replaced. Is that a commom problem with the maxima?
Old Mar 5, 2006 | 04:10 PM
Mishmosh's Avatar
Sounds good. It is not unusual for an older car to require a new starter.
Edit: If I were you, I'd consider adding a ground cable from the starter case (ie. bolt that holds in starter) to ground (either neg. battery terminal, body or engine ground). It could save you a lot of headache and future starting issues.
Old Mar 5, 2006 | 04:15 PM
Umass021's Avatar
What will making another ground cable do?
Old Mar 5, 2006 | 04:38 PM
Maxima880's Avatar
Is your positive cable in good shape. The + cable in my 97 has had it and will be replaced soon. If yours is original it can't be much better. An old cable will cause the problems you are describing.
Old Mar 5, 2006 | 08:40 PM
umair01's Avatar
my starter died out, i bought 1 from the junk yard, and it worked for 2 days, and died out, NEVER buy a starter from a junk yard, there bad!
Old Mar 5, 2006 | 08:48 PM
97green's Avatar
i have the same problem. i just bought a 99 SE with man trans. i think the problem is the starter. my also just whines sometimes. it doesnt engage due to bad solnoid. i think> not sure. it can also be a flywheel.
Old Mar 11, 2006 | 04:51 AM
MikeinMadison's Avatar
It sounds to me like the solenoid is somehow sending current to the starter without popping the starter's gear into the proper position. Be sure your flywheel isn't fried before buying a starter.
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
