lifter noise
Old Mar 1, 2006 | 06:10 PM
sky jumper
lifter noise
I think I developed a lifter tick on #1. this started a few k mi after I switched to gold GC with LC20. engine was whisper quiet before.
how do you fix a noisy lifter - adjust valve clearance?
will this cause excessive wear if not corrected?
Old Mar 1, 2006 | 06:15 PM
|Bijan|'s Avatar
UCF Lexus
I doubt its your valve ticking...
Old Mar 1, 2006 | 07:25 PM
sky jumper
not sure I understand your reply... isn't valve clearance the play between the rocker arm and the valve stem when the cam lobe is not acting on the lifter -- if there's too much play the system makes noise, a "tick", right? if not, then where is the noise coming from.
Old Mar 1, 2006 | 07:29 PM
matty's Avatar
Injectors make that noise.."tick" Ive heard soo many maxima's that tick.....check them
-matt
Old Mar 1, 2006 | 07:43 PM
sky jumper
yeah my injectors make that tick - but this is something different. a little bit lower pitch, slower, and more metallic than injector noise. and it seems like it's coming from inside the head cover as opposed to on top/center where the injectors are.
on a side note - is the injector tick a bad thing? I always thought it was normal.
thanks for the replies.
Old Mar 1, 2006 | 08:26 PM
eng92's Avatar
There are no rockers in your engine.
The cam lobe acts directly on a bucket style lifter that sits right on the end of the valve. Valve clearance in a VQ30 is adjusted through changing lifter shims. In a VQ35, you change the actual lifter.
Old Mar 1, 2006 | 09:12 PM
nismology's Avatar
Exactly...
Old Mar 2, 2006 | 08:02 AM
clive's Avatar
100% chingon
Crikey, just the same as on my 1958 XK-150SSS Jag. Hope I never have to do the adjustment.... argh. I hope the cause is not breakup of the surface of the cam lobe. I don't know if the Max uses a surface or case-hardened shaft or the whole shaft is of tool steel. Surface hardened sometimes fails.
Old Mar 2, 2006 | 09:09 AM
MaximaSE96's Avatar
Maxima Owner
all nissans have that tick.......its normal/////giggity giggity
Old Mar 2, 2006 | 12:14 PM
kcryan's Avatar
the injector tick is nothing to worry about, a little fuel power quiets but doesnt silence mine...
Old Mar 2, 2006 | 12:28 PM
bhunter's Avatar
If you drove a 3rd gen with the VTC's clacking a little tick wouldn't even get noticed. Those VE's run like a mofus though.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
