got ECU code P1440 and P1447
Old Mar 2, 2006 | 06:48 PM
hollaatchaboi's Avatar
My check engine light came on again!! Went to maximum tuning and suggested it was the sensor that connects to the evap canister (drain cut valve). However the check engine light is still on. The book at autozone saidthe code meant purge valve stuck open. Before i go buy a purge valve, has this code occured toanyone else? Where is the purge valve located? pics? suggestions?
Old Mar 3, 2006 | 06:46 AM
Zack342's Avatar
Originally Posted by hollaatchaboi
Went to maximum tuning and .....
There is your problem.
I think its located on the Evap canister. Its on the rear of the car behind the drivers side rear tire.
Old Mar 3, 2006 | 06:47 AM
is the purge valve inside the evap canister?
Old Mar 3, 2006 | 08:17 AM
Juicey's Avatar
This ORG has saved me $$$$$$$$
Looking at this diagram in the FSM it looks like there are three purge control valves.
Looks like they are all in the engine compartment. I'm looking at the diagram on page EC-410.
But I suppose you have the FSM....
Old Mar 3, 2006 | 04:00 PM
FSM?? what is that?
Old Apr 1, 2006 | 12:58 PM
MAXDADDY98's Avatar
Maxima.Org Bishes
I'm having the same problem check this thread http://forums.maxima.org/showthread.php?t=464689
Old Apr 1, 2006 | 01:01 PM
MAXDADDY98's Avatar
Maxima.Org Bishes
It's call the Control Valve
Old Apr 1, 2006 | 06:46 PM
i had changed that valve and the code still came back
Old Apr 2, 2006 | 06:27 AM
MAXDADDY98's Avatar
Maxima.Org Bishes
There is a Fuse under hood too you have to check that plus I think that there is a TSB on this issue where the dealer has to reprogram the ECU I'm not sure tho I'm still researching
Old Apr 2, 2006 | 07:05 AM
really!! dunno about this. which fuse is it?
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
