spark plug #
Old Mar 2, 2006 | 08:24 PM
maxima_kenny96's Avatar
spark plug #
whats the best spark plug to use?
Old Mar 2, 2006 | 08:33 PM
99grnmaxgxe's Avatar
NGK Platniums.
Old Mar 2, 2006 | 08:41 PM
kcryan's Avatar
Or coppers if you dont mind changing them more often
Old Mar 2, 2006 | 08:43 PM
True, but I think it's better to go platnium b/c they came like that from the factory.
Old Mar 2, 2006 | 08:45 PM
kcryan's Avatar
trueish.... not a bad way to go with either one, there both way better than bosch
Old Mar 3, 2006 | 06:12 AM
vvslavavv's Avatar
Are NGK plats better than Bosch Plat+4 plugs? and why?
Old Mar 3, 2006 | 06:15 AM
NmexMAX's Avatar
dot dot dot ...
Just go with Bosch or Champions.
Old Mar 3, 2006 | 06:26 AM
Jatan's Avatar
http://maxmods.dyndns.org/index.php?MaximaSparkPlugs
I buy NGK coppers
Old Mar 3, 2006 | 06:28 AM
dr-rjp's Avatar
I've used Bosch Plat+4's in my cars for over ten years without any problems. I changed my first set after 100,000 miles of use. The electrodes were still in good shape, but were worn down (as is expected) to where the gap became too large.
My first Max came with a new set of NGK's. They are also good plugs, but I would say that my low-end acceleration improved, as well as the overall smoothness of the engine, with the switch to Bosch.
Same thing for my I30 -- the switch to Plat+4 was an improvement in both areas.
I put Plat+4's in my girlfriend's car and daughter's car, and they are also running better.
Apparently, some of the lesser Bosch model plugs have gotten a bad rap...but I never heard any bad things about the Plat+4's.
Old Mar 3, 2006 | 06:29 AM
mbandi's Avatar
Da'Burgh, Go Stillers!
NEVER!!!!!!!!!!!!!
Old Mar 3, 2006 | 06:31 AM
DJ420's Avatar
Bad Mother Fornicator
Bro, dont put Champions in anything except yer lawnmower!! NGK Platinums OWN Bosch +4s.. use NGK, thats what Nissan uses from the factory!! The nissan part # is 22401-1P115, which are NGK PFR5G11. Use those or use copper equivelents..
DJ
Old Mar 3, 2006 | 06:38 AM
NmexMAX's Avatar
dot dot dot ...
I use Champions in my 2003, and put more N/A horsepower down than any of you weak a.s.s b.itches.
If you can beat 233whp/231 wtq.. then .. until then
Old Mar 3, 2006 | 06:57 AM
DJ420's Avatar
HeHeHeH!! BUT, I dont think it's the CHAMPIONS that are fetching you all that HP!! Hell, maybe you could pull 1 more WHP if you put the NGKs back in it!! LMAO
DJ
Old Mar 3, 2006 | 07:24 AM
mbandi's Avatar
^^^^^^YEAH, What he said!
Old Mar 3, 2006 | 08:26 AM
vvslavavv's Avatar
What's a good place to get NGKs from?
Old Mar 3, 2006 | 08:33 AM
sonicrunch's Avatar
Victoria's secret.
Same place you get your underwear.
Old Mar 3, 2006 | 12:59 PM
ManualMaxima's Avatar
5th Gen till she dies!
jesus more spark plug threads.......it is in every post what spark plugs to use.....just go buy some ngk coppers, cheap, just got o napa and you are done......
we need a spark plug sticky, for all the people without short term memory who can remeber what kind of spark plug to use that they just read in the last post the visited.
Old Mar 3, 2006 | 02:21 PM
Trajiksmax's Avatar
Proud Maxima Owner
What th HE!! are spark plugs anyways? :
Old Mar 3, 2006 | 02:35 PM
kcryan's Avatar
Ok champions are great if you swapped a briggs & Stratton 15hp into your max. enought said
Bosch plat +4's sound like a great idea, but bosch doesnt make the best plugs to begin with and the 4 electrodes allow them to last longer, but if you think about it (and yes it works this way) the 3 electrodes that aernt in use at any give spark, sheild the spark and can (and do) cause missfires because of this sheilding effect.
Just go NGK, the others may work, but why chance it NGK's and your done
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
